Hi guys if anyone can advise or had the same problem
Felt my gears got harder to shift and i decided to fill the gear box oil first. I noticed the oil drain out as i filled onve i checked for the reason i saw it dripping and cant seem to see why or what the reason might be.
Its at the bottom of the housing .
Ffz gearbox and the motor is ADY 2lt 8v
Not sure how to attach a pi
Golf 1 gearbox leaking oil
- Registered for: 4 years 7 months
- Car Model: Citi GTS 2L 8v
Re: Golf 1 gearbox leaking oil
Thers a seal where the linkage goes in the tunnel on top wheres theres a big nut check the linkage at the back of that the seal cud be damaged or best wash it off 1st to see
Sent from my SM-G928F using Tapatalk
I've checked that i found it dripping at the very bottom of the housing
Did you fill oil at the correct point? I.e at the fill up point on the side of the gearbox
- Jetta2
- Car Make: VW, VW, Aprilia
- Membership No: 1087
Jay, where exactly did you pour the oil in?
Filled at the bottom side of the box.. used a 17mm bolt to open that nut like an Allan key
Possibly over filling the gearbox with oil.
Rather get it to a reliable mech to investigate
- chucker02
- Car Model: Citi ADY
Bottom or the side? There is another 17mm allen bolt where you fill it. The one at the bottom is for draining the oil
1971 VW beetle
1971 VW beetle
- Registered for: 4 years 6 months
I accidentally threw gear oil into the wrong hole yesterday, the one where there's like a cap covering it. Sits right next to the hole where you have to throw the gearbox oil in. Car isn't idling very well.
