Good day gents.
I need some help. I have a '03 Golf 1 citi.com. As it is our 3rd vehicle it doesn't get driven often.
Lately if it has been driven for a couple of kays the front brakes lock up and won't release. I can still drive the car but the brakes get hot and obviously don't pull like it normally does.
Quick fix 1. Pulling the pipe from the intake out of the booster and pushing it back in. This immediately releases the brakes but the problem comes back shortly thereafter. (I have to add that the pipe is new but has been replaced about 2000km ago)
Quick fix 2. I have found that the brake pedal needs to be pulled back which works but it is just a short term fix.
I know I can add an additional spring to the pedal which will keep it back up.
The other solution will be quite costly. Replacing the booster or master cylinder.
Has anybody experienced this problem as I can not find anything in the forums?
Where do I start looking for the cause?
I don't want to spend money and still have the problem.
Any help will be greatly appreciated.
Golf 1 front brakes not releasing
- Car Model: Mk 1 citi.com
- grease monkey
- Car Make: Golf
- Car Model: MK2
Re: Golf 1 front brakes not releasing
I had it on a non vw and the only solution for me was to replace the booster.
Yes, from what the OP described under quick fix no. 1, it does sound as though the booster's working valve, which is normally only operated by the push rod from the pedal, is leaking air into the booster's working chamber, thereby pushing the membrane towards the master cylinder.
- Car Model: A4 2.0T
I had this once on an Uno.
Turned out the brake lines were collapsing. Hit the brake the pressure builds and engages brakes. Foot off brake and brake hose would collapse and cause the brakes to seize. Only happened when hot.
Replaced brake hoses and bled the system and problem went away.
