RSI Injector impendence
Baldwin02002
Car Model: Mk2 GTS
Post by Baldwin02002 »
Hi guys, tried searching but not finding an answer. i would like to run my 16v 2.1 motor with RSI throttles 11.0 Compression because of Mazda flat top pistons . My worry is:
MP9 2L injectors VS Rsi injectors on the below factors:
Flow:
impendence:
Voltage/current:
Please help before i mount the motor as it was running on dictator. Thanks
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
Car Make: VW, VW, Aprilia
Re: RSI Injector impendence
Post by Jetta2 »
MP9 -
Flow: 185cc at 3 Bar fuel pressure
Impendence: 14 or 16 Ohm (can't remember the correct value)
Voltage/current: Obviously 12 volt.
RSI (Google info) -
Flow: 295cc at 2.5 Bar fuel pressure
Impendence: 12 to 14 Ohm
Voltage/current: again, obviously 12 volt
Baldwin02002
Car Model: Mk2 GTS
Thanks, they will work with the MP9 system as they are high impedance. That's all i wanted to know. Cool
S4 2004 --> Stock
Previous
Jetta 4 V5 10V
Honda CB400 '74
