Polo 6N 1.6 Misfire when cold
BeastMK22
Post by BeastMK22 »
Morning All,
Got myself another polo after a 5 year hiatus, just had to come back :grin:
So this is the issue and need some direction so I can tackle this issue over the weekend. The car struggles to start when cold - I have to give it a few swings before it splutters into life and I have kind of keep tapping the throttle to keep it going for a few seconds. After with the car will idle but I can hear a misfire or splutter.
When I depressed the accelerator it will either die or splutter up the rev range. This misfire happens until it gets warm and I drive it a few minutes after which it goes away. During this time it smokes but I can smell its over-fueling.
My basic knowledge lends me towards a fueling issue somehow but need some input here on where to start.
Any help would be appreciated.
Thanks!
Astra Turbo Coupe
Ex's:
Polo Classic 1.6i(6n) Millennium Edition: 50mm freeflow and down-pipe; k&n flat panel filter; & Tuning ARt Coilovers.
Golf II 2L 8v "The Beast" (Flowed & ported head; Wildcat 4-2-1 branch, 50mm Powerflow; 272 cam; Twin Weber 40s; KS pistons & 2l Lightened crank)
BMW 518i e12 "The Tank"
missioner
Car Model: '87 MK1 Golf Citi
Re: Polo 6N 1.6 Misfire when cold
Post by missioner »
Start with the basics and check the coils, leads and plugs.
The fuel you are smelling is likely unburnt fuel in the exhaust.
It may be as simple as water in the plug wells or a bad plug lead.
Or even the maybe classic faulty water temp sender. Comon issue on mp9.
BeastMK22
Post by BeastMK22 »
missioner wrote: Wed Aug 14, 2019 10:37 am Start with the basics and check the coils, leads and plugs.
Will give this a go.
panic-mechanic wrote: Thu Aug 15, 2019 7:23 am Or even the maybe classic faulty water temp sender. Comon issue on mp9.
Going to Goldwagen later today so will get a new temp sensor while i am there.
Thanks gents
Astra Turbo Coupe
Ex's:
BeastMK22
Post by BeastMK22 »
Quick update - it was the water temp sender. Replaced and car is sorted. Thanks Panic!
Astra Turbo Coupe
Ex's:
