Connect to gotech MFI PRo VR6
- Car Model: Jetta VR6
Hi Guys I have a problem, Im trying to connect to my gotech mfi pro on my VR6 jetta but i am unable to succeed.
I have tried the serial converter to USB -does not work
I got an old laptop with the serial port - Does not work
I have checked the COM port settings - No result
Can someone please assist me with this not sure what else i need to do.
Re: Connect to gotech MFI PRo VR6
Did you install the usb to serial driver for that converter on your laptop? If so you need to go to the usb settings in device manager and set the COMM port and baud rate to the same as the baud rate specified on Gotech. Same applies for the serial port on old laptop. COMM port and baud rate set on laptop must match what is selected on Gotech software selection.
Hi Thanks for the reply
Yes I have done that, installed the drivers on two different converters
Yes I have check the settings device manager
Bit per second : 19200
Data bits: 8
stop bits: 1
Flow control: None
This is the settings on the gotech software when trying to connect
COM1-10 19200,n,8,1
Data bits: 8
stop bits: 1
Flow control: None
COM1-10 19200,n,8,1
Just to clarify, did you set both to eg, COM3 to have like for like COM port name? COM3 on laptop and then COM3 selected on software.clayton136 wrote: ↑Sat Aug 10, 2019 3:11 pm Hi Thanks for the reply
Data bits: 8
stop bits: 1
Flow control: None
COM1-10 19200,n,8,1
There is only comms when ecu is powered.
The thing is on the software it scans through all the COM ports but does not dectect anything.
There is no place where i can define the port like on the dictator software
Name of the software is Dealer tune
I’m now out of more ideas.
Thanks for you assistance anyway
Anyone else ?
Anyone else ?
- Membership No: 3103
Whats your computer serial port number?clayton136 wrote: ↑Sat Aug 10, 2019 3:11 pm Hi Thanks for the reply
Data bits: 8
stop bits: 1
Flow control: None
COM1-10 19200,n,8,1
It should be between 1 & 10 for software to pick it up. Usually after installing the drivers the serial port will pick the available number and you can manually set it to COM 2/3/& etc.
I hope that helps. Its pretty easy to connect to Gotech via serial
'09 8P S3 Sportback (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
'10 B8 S4 V6T (DSG)
'15 6C GTi (MT)
Hi it was COM2 but i have changed it but stil no result
just go the gotech themselves and let them test the box. no use trying a 100 different things and the box is actually blown.
Thanks for the advise....
- Registered for: 4 years 4 months
Hello all well I'm new to this site
I just bought a golf 3 gti for R8000 yes it need's some work it has been standing for 2 years it has a Gotech mfi in I'm busy redoing the wires because some of the wires are really thin and not up to standard what do you guys think of the mfi
Does anyone have a wiring diagram of the mfi
