Good day Members
I hope you are all well,
Can anyone kindly please help with me with a dicktator map for a 2l 8v mk1. I live in limpopo and the closest Tuner is about 300km away.
I can only drive to the tuner, towing will be just too expensive.
I know my way around the basics of the software and the car is staring and running
please pm if you can help, ill buy you a beer or airtime
Dicktator Map please
- Car Model: MK1 2E Dicktator
Less noise More Speed
2l 8v
Dicktator
2l 8v
Dicktator
Re: Dicktator Map please
thanks guys the car starts and is idling fine,
Does anyone know why the car only starts and idles fine when ignition is divided by 1 and not 2?
The map sensor was causing the ECU to shutdown so changed to tps.
When i blip the throttle slightly it seems to hang and takes a while to return to normal rpm, could this be idle response settings or the throttle compensation setting decay , deed band ect? I have checked for intake leaks but cant spot any.
any input will be highly appreciated I'm getting the car ready for dyno, the dyno is about 300 km away and i need to tow the car there,
i just want to make sure that i wont need any mechanical replacements once the car is at the dyno.
2l 8v
Dicktator
2l 8v
Dicktator
