Polo 6C GTI DSG Stage 1
- neil_fladderak
- Car Model: Polo 6C 1.8 GTI DSG
Hi, there was wondering if anybody can help in giving more info on if it's worth it to do stage 1 software on my 2017 Polo 6c GTI DSG, where would the best place be to go (Im based in Western Cape) and would i have to worry about my DSG or the Clutches not being able to handle the extra grunt provided?
Thanks guys
Thanks guys
'17 Polo 6C GTI DSG
- Stock ECU/TCU Software
- 152kw 282nm on flywheel at Dynotech (runs were without below mention hardware)
- RoguePerformance 76mm Dp
- Stealth Atom 2 CAI
'17 Polo 6C 1.2TSI Highline Manual WRC Inspired (Stage 1 Tuned, TWEEK CAI, Powerflow cat-back exhaust) viewtopic.php?f=11&t=212395&p=2569296#p2569296
'06 Polo 1.6 Comfortline (Stock)
'05 Corsa 1.6 Sport (Stock)
'17 Polo 6C GTI DSG
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Re: Polo 6C GTI DSG Stage 1
CPI does plug & play units for these models, a good place to start will be your local CPi dealer.
- neil_fladderak
Will pop them an email and find out a bit more on the plug n play units thanks I did 2 power runs at Dynotech the other day in stock form with only a resonator and muffler delete and the car made a healthy 152kw and 282nm compared to the supposedly expected 141kw and 250nm Was pleasantly surprised to say the least
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
- FanMan
- Car Model: Polo 1.9 Tdi
Yes I agree, CPI has a good reputation and if I'm not mistaken they running a special now or had one for down-pipe and software for like R5k. Or was it some other tuner ? Hmm, cant remember. But check them out on Fb , https://www.facebook.com/CPICPT/
Even JP Motorsports a rep for RK Motion is also good, but i think they more into Diesels. But you can check them out, https://www.facebook.com/jpmotorsportsa/
you can also check out this vid on youtube to get your adrenalin pumping and excited.
https://www.youtube.com/watch?v=IvtDXakDlfw
Current : VW Polo 1.9 Tdi Sportline Big Turbo
https://www.vwclub.co.za/forum/viewtopi ... 1&t=216892
Previouse :
1. Vw Beetle 1.4 1974
2. Vw Beetle 1.6 1982
3. Opel Corsa Utility 1.4i 1999
4. Vw Golf City Sport 1.4i 2009
5. Vw Polo 1.9 Tdi Highline 2007
6. Vw Polo 1.9 Tdi Sportline
7. Vw Polo 1.9 Tdi Classic
Previouse :
- Car Model: 2016 Polo GTi DSG (6C
Wow...All this power from only a muffler and resonator delete?neil_fladderak wrote: ↑Fri Jun 07, 2019 2:28 pmWill pop them an email and find out a bit more on the plug n play units thanks I did 2 power runs at Dynotech the other day in stock form with only a resonator and muffler delete and the car made a healthy 152kw and 282nm compared to the supposedly expected 141kw and 250nm Was pleasantly surprised to say the least
- neil_fladderak
I think my car was made on a wednesday , cause i stopped at a robot with another white 6c gti dsg and i smoked him from the get go, and that was the day after i got my car when it still had the standard exhaust, theres no way according to my knowledge that a resonator and muffler delete will give 11kw and 30nm gains.jaunrothner wrote: ↑Fri Jun 07, 2019 2:42 pm Wow...All this power from only a muffler and resonator delete?
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
- neil_fladderak
Here's the Dyno Results from the 2 power runs at Dynotech in Brackenfell, Western Cape from 3 weeks ago:
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Maybe the previous owner tweaked the car a bit as wellneil_fladderak wrote: ↑Fri Jun 07, 2019 3:00 pmI think my car was made on a wednesday , cause i stopped at a robot with another white 6c gti dsg and i smoked him from the get go, and that was the day after i got my car when it still had the standard exhaust, theres no way according to my knowledge that a resonator and muffler delete will give 11kw and 30nm gains.jaunrothner wrote: ↑Fri Jun 07, 2019 2:42 pm Wow...All this power from only a muffler and resonator delete?
- neil_fladderak
Doubtful, my car was in for warranty repairs so if there was software done to it, the dealer would have notified me that they can't do warranty work
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
- neil_fladderak
So i contacted CPI and they said they can do a plug n play unit on my car and it's undetectable by vw, how true is that? I don't want to risk my warranty
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
If you can't risk your warranty then don't mod.
- neil_fladderak
This isn't answering my question about the plug n play unit being undetectable or not.
Warranty expires start of next year so will defs start fully modding, but for now just want something simple that'll increase power a bit.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Ok so let's change this into a morals thread instead of whether it is detectable of not.
What you are asking is if it is morally correct to modify your car or not.
So the plan is - you want to mod - but want to be able to claim if it goes wrong. YES?
SO basically it means you will lie when it goes bang. and you'll be Ok with that?.
- neil_fladderak
Not Entirely, it's more a case of, i've had issues with my gearbox with no mods already, i know the car can handle said mods (plug n play) as i have a lot of friends who have done it with the same model car and gearbox, but i'm paranoid that my gearbox gives the same issues again which is not a result of the car having more than stock form power.panic-mechanic wrote: ↑Mon Jun 10, 2019 11:58 am Ok so let's change this into a morals thread instead of whether it is detectable of not.
This lack of faith is a result of VW not being able to tell me what caused the gearbox to break the way it did, I hope this makes sense?
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Yes perfectly. All your friends are happy to lie when their cars fail due to mods.
- neil_fladderak
panic-mechanic wrote: ↑Mon Jun 10, 2019 12:58 pm Yes perfectly. All your friends are happy to lie when their cars fail due to mods.
The first thing they do is ask for advice and explain what failed in our group
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
It's pretty simple. Piggyback / plug and play devices are not easily detectable unless the car records things like max boost levels etc.
So stick it in your car and live with the moral question of whether you will claim if it fails. To that my answer always have and always will be - put your big boy pants on when the thing conks out and foot the bill - don't try to claim it from warranty. But hey - morals are at an all time low - so who cares.
You pay for it right?. like insurance - nobody lies on their insurance claim do they. Because that is equal to fraud. Yes?.
- neil_fladderak
True, and i don't mind paying for something that failed cause of mods that i've done, i'll happily pay the bills for the repairs, but do you think they will fix something under warranty that has failed in the passed even before the car was modded now with said mods? Thats the big question.panic-mechanic wrote: ↑Mon Jun 10, 2019 1:26 pm It's pretty simple. Piggyback / plug and play devices are not easily detectable unless the car records things like max boost levels etc.
You will be surprised how many people lie on insurance claims and commit fraud just to save their own asses from big repair bills . I for one haven't and won't ever do such a thing.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Then no worries. Install your plug and play and remember to tell VW when something fails to make sure it was not due to the non-detectable piggyback you had on. Which is why it needs to be non-detectable right. So you can do the honest thing.
If your gearbox was unreliable in stock form, I would not do the mod and put more stress on it. But that is just me.
1977 Datsun 1200GX
Wife's car: 2019 Suzuki Ciaz
1977 Datsun 1200GX
- neil_fladderak
The failure happened just short of a month after i bought the car, so not sure if it was something i did or from the previous guy who drove it for VW at the factory as they said it was a factory demo and only used by one person till i bought it. The car has been running 100% so far since march now. I'll probably go the JB4 route at the end of the year when my warranty expires if my gearbox hasn't given any issues up until that point.HendrikCTI wrote: ↑Mon Jun 10, 2019 2:11 pm If your gearbox was unreliable in stock form, I would not do the mod and put more stress on it. But that is just me.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
- neil_fladderak
Mate I would really appreciate normal replies as opposed to your sarcastic replies, if you can't respond in a normal way than rather don't reply to this topic at all.panic-mechanic wrote: ↑Mon Jun 10, 2019 1:49 pm Then no worries. Install your plug and play and remember to tell VW when something fails to make sure it was not due to the non-detectable piggyback you had on. Which is why it needs to be non-detectable right. So you can do the honest thing.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
Ok here it is without sarcasm. Nobody asks if something is not detectable if you are not wanting to hide the fact that it is/was installed.
If it didn't bother you and you don't care about the warranty then you would not care if it was discovered. The truth is that you doubt that you can afford to fix it without warranty when / if something goes wrong. So once more, if you need the warranty to be intact then don't mod your car.
It is simply outright and straight dishonesty and tantamount to theft/fraud and there is way too much of that going on. The fact that a lot of people do it does not make it right and it's also part of the reason why maintenance plans / warranty options are so damn expensive and why it is sometimes so hard to get stuff Ok'ed at claim time these days.
- FanMan
Just wait for the warranty to expire next year. You have been driving it this long without the extra power.
And when the warranty expires go all out, with Down-pipe and Software,
Previouse :
Previouse :
- neil_fladderak
I agree with you 100%, I won't be able to afford it if something goes wrong out of warranty this year so i'll wait till my warranty expires next year.panic-mechanic wrote: ↑Mon Jun 10, 2019 7:53 pm Ok here it is without sarcasm. Nobody asks if something is not detectable if you are not wanting to hide the fact that it is/was installed.
'17 Polo 6C GTI DSG
'17 Polo 6C GTI DSG
