MK7 GTI horn not working
sbu.mah
Registered for: 9 years 2 months
Car Model: MK7 GTI
Post by sbu.mah »
Hi Gents
Noticed this morning that my horn/hooter is not working, not sure when this happened as I hardly use it.
How does one diagnose the problem, without going to the stealership
Sent from my SM-N960F using Tapatalk
MK7 GTI
Revo Tuned
Revo Intake
Roque Performance DP
Re: MK7 GTI horn not working
You equip yourself with a multimeter and start testing.
Hoosier Daddy
Car Model: Golf VI R
Membership No: 2023
Post by Hoosier Daddy »
panic-mechanic wrote: Thu Jun 06, 2019 9:08 am You equip yourself with a multimeter and start testing.
Feels :lol: :lol: :lol: :lol:
My Dream: Gipsy Danger
My First Love: Lucy
Nikz_tsc wrote:Don't be an elachi bhai
sbu.mah
Car Model: MK7 GTI
Post by sbu.mah »
Ian I don't even know where to begin. Only time I use a multimeter is to check voltage on some electrical stuff
MK7 GTI
Revo Tuned
Revo Intake
Belix
Registered for: 14 years
Car Model: Passat B8
Post by Belix »
Most likely fail point I would think would be the fuse, the steering wheel switch and the relay.
First check the fuse.
Check the wires to the hooter horn are still connected.
If that's good, when you press the hooter, do you hear a relay click?
If you can get to the horn, use the multimeter to see if you get 12V across when you press the hooter.
If not, work backwards to the relay if you can find the right one.
Yup. Using the voltmeter to check the voltage on some stuff is exactly what you will do.
belix expanded it some for you. getting to the horn might be real PITA as they are hidden behind the bumper cover.
NHB_R
Post by NHB_R »
Time for a new car
Abnormal
Registered for: 20 years
Membership No: 848
Post by Abnormal »
NHB_R wrote: Thu Jun 06, 2019 1:36 pm Time for a new car
:lol: :lol:
\Oo) \ _w_ / (oO/
