Cement in engine block
- Car Model: Mk5 gti
So I read an article and watched a video on this. alot of people overseas and a few local have been doing this they are putting some kind of special cement like mixture into the engine block of turbo charged cars. Apparently you can boost the car much more than it would normally hold up ...just curious to learn about it .dont plan on doing it lol... how is this done and why would one do this ? How would the water and oil flow if there's cement in the channels ? And wouldn't this cause the engine to heat up ?
viewtopic.php?f=11&t=217296
Previous :too many to list
- Uncle Nunda
- Post Whore
- Car Model: S3
- Membership No: 1489
- Car Make: Merc
- Car Model: C63 Edition 507
Re: Cement in engine block
they don't fill the whole thing they only do some of the channels - Steven from JMS did this in Ashay's uno turbo many moons back- that thing was flipping strong
Polo 20VBigT - The Redhead
C63 507 Edition - The Dragon
Isuzu 4x4 - Little Joe
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
Yarrrrrr... ratchet to the max!!!
Next post:
"How to remove cement from engine block"....
- Colonel
How the **** do you 15000 posts???!!!! you whore
- dcmk4
- Car Model: MK7 GTi
Throw the engine into the foundation for a building, it will strengthen it
It being the foundation until the block rusts away
- PoLonY
- Car Model: A8
- Membership No: 1997
Actually notHoosier Daddy wrote:Yarrrrrr... ratchet to the max!!!
There is special block “cement”
The GTR boys with the RB26 did it plenty, filled half of the bottom of the block with it to support the sleeves
You don’t fill the whole thing
It acts like a sleeve brace basically
Strengthened the block and prevented the twisting that lead to the straight 6 cracking the casting between cylinder at high rpm and torque
Required improved water cooling setups etc which they already did anyway and flow to allow for adequate cooling but they no issues with it
- M3THANOL
- Blue Bomber
- Car Model: Golf Mk2...now....2.0L 8V AGG
- Membership No: 1822
They have been doing this for YEARS in the drag racing scene!!
As far as I remember it was very common on engines running on methanol, because most of those drag motors don't have any engine coolant anyway, they don't have a radiator. The fuel itself cools the intake charge when it vaporises and as a result doesn't generate heat as quickly as normal gasoline would.
I'm literally can't evening!
http://www.iamsecond.com/
Current: The Blue Bomber
http://www.vwclub.co.za/phpbb3/viewtopi ... 1&t=151592
1/4 mile: 16.5s @ 133km/h (ODI-2013/10/27)
1km: 165km/h (ODI-2013/10/27)
- PoLonY
- Car Model: A8
Yup!M3THANOL wrote:They also have been doing this for YEARS in the drag racing scene!!
Nothing new
- M3THANOL
- Blue Bomber
These days they just use more modern materials, often using a type of epoxy, from what I've read
- PoLonY
- Car Model: A8
Yeah it is epoxy based iirc
- M3THANOL
- Blue Bomber
Here's a forum where the guys discuss the different types and the reasoning behind it
http://www.thedirtforum.com/technical/E ... 03282.html
I have not heard of people doing this for a road used car. Only ever heard of it being done in the drag racing where you then eliminate cooling completely. The short time it takes to do a burnout and a run on methanol / ethanol or nitro motors does not need the motor to be water cooled.
I would not suggest that for your daily or track racing car.
Hi Stefan makes total sense what u saying but I'm a little bit lort confused lol... doesn't an engine have to be at operating temperature before u high rev it ...ive always known since a teen to always warm up the engine before driving ...do these guys race the engines when it's cold ? Or does it simply not get hot by doing this ...and also how long does the cement last ? Do u have to keep on replacing/refilling the cement or is it a once of thing?panic-mechanic wrote: ↑Thu Jun 06, 2019 8:57 am I have not heard of people doing this for a road used car. Only ever heard of it being done in the drag racing where you then eliminate cooling completely. The short time it takes to do a burnout and a run on methanol / ethanol or nitro motors does not need the motor to be water cooled.
But why use cement ? Is it not possible to use metal instead ? After all steel is stronger than cement my minds working overtime lolPoLonY wrote: ↑Thu Jun 06, 2019 8:33 amActually notHoosier Daddy wrote:Yarrrrrr... ratchet to the max!!!
Warming an engine before revving or driving hard is generally just for longevity of the engine/prevent the engine from dying early. Since most wear happens when cold or on the warm up period of an engine.
On race engines, they don't care about wear - they are built to be abused with different clearances and stuff compared to the normal production line daily/sport car engine.
And those engines get rebuilt quite often, those stupid fast cars get an engine rebuild after every season or something like that.
- PoLonY
- Car Model: A8
It’s a liquid epoxy based cement with the correct thermal properties etcTrishen94 wrote:But why use cement ? Is it not possible to use metal instead ? After all steel is stronger than cement my minds working overtime lolPoLonY wrote: ↑Thu Jun 06, 2019 8:33 amActually notHoosier Daddy wrote:Yarrrrrr... ratchet to the max!!!
It’s just a void filler that removes the ability for the casting to flex etc
Else you’d have to pour molten steel into a cast block
Won’t end well lol
Makes total sense to me now after getting all this Info from u guys ...still watching a few videos and man it's amazing woulda never expected this method ...totally agree with polony pouring hot metal might do more harm than good on the cast iron block ...glad I asked lol otherwise it woulda been another sleepless night on Google
