Hey guys
So im trying to help out a mate mine
I only got to check out the issue when it was already dark. Will probably only get a proper chance this weekend as i do arrive late.
But thought id do some research on this leak on the geabox of the car its a Polo 9n3(Blm motor) the leak seems to be coming from above the gearbox its clear in color...im thinking could be gearbox oil from a worn seal but just need to make sire
Anyone know what it could be....
Geabox Oil leak
- Wolfburger
- Registered for: 8 years
- Car Model: 6C Cross Polo
Geabox Oil leak
Current: 2015 6C Cross Polo TSI(Honey Orange) - Ginger
2009 Golf 5 GTI DSG - OEM Look - Sold
2007 Polo 9N3 Black Magic - Sold
1998 Bottle Green Jetta VR6 Executive - Sold
Admin to : https://www.facebook.com/pg/ScenePointsSa
Re: Geabox Oil leak
brake fluid from the slave cylinder
- Wolfburger
Re: Geabox Oil leak
Thanx panicpanic-mechanic wrote:brake fluid from the slave cylinder
Where is this cylinder located and does it require for the entire replacement of the cylinde? Or just some seals?
Re: Geabox Oil leak
ALL your pictures has the slave cylinder centered right in it. there is a metal hose attached to a piece of flexible hose then onto metal hose again that clips into the slave. it is slightly hidden by the battery tray in the picture.
I cannot answer your question on what it needs but these days you don't even get seals for them. you just buy the whole thing complete.
- Wolfburger
Re: Geabox Oil leak
Thanx managed to search the InterWeb and found it - Will replace weekend
