Jetta 3 1.6i no spark
Good day
My Jetta 3 1.6i does not have spark.
I noticed that the black wire connected to the 3pin coil has + current. When i crank the engine it loses current.
Some instances when i switch my acc on it sparks ( i connnect a plug onto the wire from coil to distributor) and when i switch off my acc it sparks.
I also have a wires buzing noise from the back of my cluster and all function on it is disrupted when i switch on my acc. My ODO numbers also becomes (0U000).
What could be the cause.
Your reply will be greatly appreciated.
Re: Jetta 3 1.6i no spark
sorry what is this 'acc' thing you talk about?.
- Registered for: 13 years
- Car Make: mk1
- Car Model: GTX
ACC=Position on ignition switch
useless comments deleted.
No idea why your car don't spark.
Last edited by panic-mechanic on Mon Jun 10, 2019 11:06 am, edited 1 time in total.
Oh gosh
Didn't asked to be corrected. If you cannot advise on 'car with no spark' question better than you dont share your useless comments.
- Car Make: SEAT
- Car Model: 2014 Golf 7 1.4 comfortline
My thoughts as wellSupervan II wrote: ↑Mon Jun 10, 2019 12:43 pmLOL, methinks you just blew any chance of anyone on here helping you.
IDIOT!
Current- 2014 VW Golf 7 1.4 comfortline
Ex- 2011 Opel Corsa 1.4
Ex-2006 Opel Astra 1.9 GTC
Ex- 2006 VW Polo 1.6 comfortline
Ex- 1993 VW Golf GTI
Thats fine saw plenty guys with same issue and read all the threads and noticed nobody offered a real solution.
It's because without seeing the car it is anybodies guess as to what the problem is. It can be hall generator in the dissy, it can be the ignition switch (which should not have an acc setting and it will not have spark during the acc setting if it does) - it could be some or the other completely other electrical fault like bad earths. etc etc.
it could be the tp100, it 'could' be anything.
these type of things you take a volt meter and you start testing what has power and what does not and figure it out from there. Nobody is going to magically just know sadly.
- Car Make: SEAT
