Golf mk1 1.8 Carb - 1984/6
Posted: Tue Apr 16, 2019 4:46 pm
by ShizoQue
Hello guys, im having trouble with my golf. okay she will start up and idle for hours, but soon as we take her for a drive, 5 minutes and she cuts off. we have changed fuel pump, tank, distributor, carb, module.
is there any other ideas as to what could be a problem that we need to see to?
Re: Golf mk1 1.8 Carb - 1984/6
Posted: Tue Apr 16, 2019 5:37 pm
by Phat1983
Fuel Line blocked or collapsing maybe?
Posted: Tue Apr 16, 2019 5:38 pm
by Phat1983
Posted: Wed Apr 17, 2019 8:46 am
by panic-mechanic
Float level, spark etc etc. you ned to see what disappears, spark or fuel. So take a loose spark plug with. When it dies pull a plug lead oof.mput younloose plug on, put it on the engine and see if it makes spark. If so you know it is fuel related.
Posted: Wed Apr 17, 2019 9:25 am
by -=sT3V3=-
Once she cuts off, how long till she starts again?
Posted: Wed Apr 17, 2019 4:48 pm
by Ryandevraj
ignition switch maybe
Posted: Wed Apr 17, 2019 5:02 pm
by Yakuza Racer
feel the coil. If its pows hot ,change it.
Posted: Fri Apr 19, 2019 11:12 pm
by missioner
Block off the return line from the fuel pot in front of the air filter and see if that helps.
