Good day.
If I don't use my car one day the next day it wont start...
After jump starting it then it will be all good until I don't use it again.
So I assume that the "brushes" on alternator is ok if the battery charge if I can start the car successfully any other time.
What is draining the battery then???
I even switch off the light switch and I don't have a sound system. Car is standard.
Please give me some ideas...
Regards
GOLF 5 GTI battery running flat after 1 day???
if you wanna hang out with the dogs, don't p@%$s like a puppy.
- WeirdSteam
- Car Model: A3 Sportback 1.8 TFSI
Re: GOLF 5 GTI battery running flat after 1 day???
How old is the Battery and when last have you had it tested.
Sounds like a dead cell
Sent from my WAS-LX1 using Tapatalk
- Car Model: Mk5 Golf GTI
Did you change the radio on the car by any chance?
Yes I installed a 2Din DVD unit... What did I do wrong. I bought the car in June so not sure how old the battery is.
- Membership No: 2033
Some of the HU's cause parasitic drain on the battery, even when off. Do a search there is a how to wrt this....
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- nolan.chettiar
Had the same problem. Google the fuse box mod. Will cost you like 5rand. Never had a problem since.
HOWIE-WP,
- ICE King
Does your HU switch off when you pull your key out ignition? If not, it's connected wrong so it constantly draining even when not on.
Thanks all.
I will definitely look into all of your options.
Regards
Regards
