Howzit guys
Does anyone have a running map for a std dicktator 1.6i 8v motor previously mp9?
I need to be able to drive the car, but cannot get a tune at the moment.
Thanks in advance.
1.6i 8v dicktator map needed
- Car Model: Citi 1.6i
Re: 1.6i 8v dicktator map needed
Anyone? Willing to pay a small price for the file
You should have this map on the cd with the ecu, when you purchased it.
The files on the cd is startup files only and needs tuning after startup. Would not be setup for run in or driving.
Checked the 1.6 8v map on the cd I have. You need to change the trigger edges all 3 to default.
If you hadn’t got this sorted yet, pm me your email address and I can send you a startup map.
how are you bra... Sorry to bother you.... I recently bought my STD dicktator for my Mk1 1.6...
The car start, but it dies after couple of minutes, I believe that it's because the map is not tuned, it idles rough with the petrol pump plugged in, but idles smooth when I disconnect the pump but eventually dies because of no fuel....
Can you please assist me with a tuned map??
I would very much appreciated you help.... Even if you slightly charge me
Thanks in advance...
My email address
theodore.mohlala@gmail.com
My email address
Wire it up to the fuel pump wiring from Dicktator and then try againMAKGOKE wrote: ↑Thu May 05, 2022 1:45 pm how are you bra... Sorry to bother you.... I recently bought my STD dicktator for my Mk1 1.6...
My email address
How are you doing bra....
Do you have any idea how I could have got my fuel maps blown on my STD dicktator box? Because my boost is reading OVER instead of 0.08 or 0.18
