Mk7 Heater system working intermittently
Gti3
Post by Gti3 »
Hi Guys
been having intermittent problems on my 2013 Mk7 Golf Tdi. sometime there is heat, sometimes there isn't.
I have flushed/reverse flushed the heat radiator that sits in the dashboard as well as radiator looking thing under the airbox (mounted to the gearbox).
It seems to be working for now but will have to monitor for some time.
So the question is - Please can any of you advise if there is perhaps a valve somewhere in the engine bay that allows water to move to the heater radiator when the heater is switched on? or is the water always circulating through it ?
Thanks.
2020 MK7.5 GTi DSG
EX:2013 MK7 TDi HIGHLINE DSG
EX:2010 MK6 GTI 6MT
EX:2006 Ibiza Cupra TDi
EX:1993 Golf 3 Gti
EX:1970 Beetle 1600 Twinport
Lence
Re: Mk7 Heater system working intermittently
Post by Lence »
Hi guys. I drive a polo classic 1.4 1999 model , my rev count and speedometer has stopped working , how can I fix this? I’ve also tried to replace the cluster but I still got the same problem. Kindly help
Wolf Mk2 16V
Registered for: 9 years 8 months
Post by Wolf Mk2 16V »
Are you sure it is not the climate control system, I know some cars had issues (mine included) with controls?
2015 VW Golf Gti
1987 Golf GTS
1993 Citi Golf Designa 1800
2015 VW Move Up!
Le Clue
Registered for: 14 years 6 months
Car Model: Golf Mk7 GTI Clubsport
Membership No: 1458
Post by Le Clue »
Have you scanned the vehicle with VCDS? And do you have Climatic or Climatronic?
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
Gti3
Post by Gti3 »
Hi guys, have not scanned with vcds.
I'm not sure if it's climatic or climatronic. It does not have dual zone, that much I know, and the temp knob does not have the numbers/degrees like my mk6 Gti used to have. It's just blue on 1 side and red on the other side.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
madracer21
Registered for: 15 years 5 months
Post by madracer21 »
Lence wrote: Thu Jul 05, 2018 8:20 pm how can I fix this?
Create your own thread for starters.
Gti3
Post by Gti3 »
madracer21 wrote: Fri Jul 06, 2018 11:27 pm
Agreed !
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
Just some feedback guys, since doing the flush, the heater seems to be working fine thus far. Will give it a few more days and let you guys k ow how its going .
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
Aaaaaand the problem is back....was on my way up to GP and just when I needed the heater at Noon River..... nothing! Will have to get the car scanned to see if that reveals anything. Results will be posted as soon as I manage to get it done.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
Gti3 wrote: Mon Jul 16, 2018 3:41 pm Aaaaaand the problem is back....was on my way up to GP and just when I needed the heater at Noon River..... nothing! Will have to get the car scanned to see if that reveals anything. Results will be posted as soon as I manage to get it done.
Have had teh car scanned and did not reveal any faults.
An additional bit of information - there is a gurgling sound coming from the dashboard from the heater core region amd there is also an intermittent 'clicking' sound. Mainly notice this when i switch the car off after a drive of approx 1 hour or so
Any ideas guys ?
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
I think i have the Climatic A/C system as its not dual zone.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
Gti3
Post by Gti3 »
Hi All
Update after a long while. I am still battling with this and the car is taking about 750ml of coolant for every 650kms. Been to an aircon shop and the guy advises that the Heater Core may be leaking and quotes approx 5k to repair. I have however done a pressure test on the cooling system and there is no drop in pressure detected, nor are there any signs of dampness inside the car.
Please can someone advise if the Mk7 Golf has a control valve which controls the flow of water to the heater core? If so, please can you let me know the location.
I am also thinking about bypassing the heater core to test another theory i.e. that the core may be blocked which is causing a pressure build up and therefor causing the coolant to leak form the reservoir overflow (i do see signs of dry coolant around the reservoir)
help guys
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
markfish888
Car Model: B7A4 -JETTA Mk2
Membership No: 1787
Post by markfish888 »
Shot in the dark, was system bled properly? air in system, might explain drop in coolant , as coolant replaces air.
When you flush/refill/bleed, dash heater controls must be @ max hot and fan speed @ max speed.
Do not use any coolant other than G11/ G12 spec, and distilled , or at least boiled water.
https://www.audiworld.com/forums/a4-b6- ... m-2859854/
Gti3
Post by Gti3 »
markfish888 wrote: Fri Feb 15, 2019 2:21 pm Shot in the dark, was system bled properly? air in system, might explain drop in coolant , as coolant replaces air.
Thanks, will give it a shot, but I think the golf 7 has a heater system which constantly flows water through the heater core. I am using G13 coolant.
I am not seeing any signs of water over flowing from the water bottle anymore, now that I have the heater bypass in place, now I need to figure where the water is going....
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
BKj
Registered for: 4 years 6 months
Post by BKj »
Hello Guys,
I'm new to this forum. I came across it thread as i am experiencing the exact same issue, with the same make and model 2013 Golf 7 2.0 TDi.
I would like to know has this issue been resolved? if so, What was the problem?
Thanks.
Gti3
Post by Gti3 »
BKj wrote: Thu Sep 19, 2019 1:12 pm Hello Guys,
Thanks.
Hi
Yes I did resolve it. It was 2 separate issues, water loss was from the EGR cooler and the heater problem was a clogged heater radiator.
I bypassed the EGR cooler pipes and needed software the write out the EGR process.
For the heater, I bought a new radiator from VW and replaced myself, was about R3300 for the radiator.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
BKj
Post by BKj »
Gti3 wrote: Thu Sep 19, 2019 1:15 pm
Thanks.
Hi
Hi
Thank you for the prompt response. At least this points me in a direction i will have the radiator tested and take it from there.
Thanks again.
Gti3
Post by Gti3 »
BKj wrote: Thu Sep 19, 2019 1:38 pm
Thanks.
Hi
Hi
Thanks again.
Even with the blockage in my old heater radiator, the water still flowed though it, which had me baffled. The only time I realised how bad the blockage was when I bought the new radiator and blew threw it. On the new radiator there was no effort at all, it was easy as breathing out normally. With the old one, the air flowed, but there was a bit of resistance.
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
BKj
Post by BKj »
Gti3 wrote: Thu Sep 19, 2019 2:17 pm
Thanks.
Hi
Hi
Thanks again.
So i got my car back on Friday. Turns out the heater core/matrix was completely blocked. After your first response i decided to approach the issue as 2 separate problems, Thank you. I booked the car in with air-con specialist and they resolved the heating issue for me by flushing the system and replacing the heater core, as they could not salvage the old one.
Now i just need to keep an eye on the coolant level to see if the issue was related or not. If the coolant drops again i will take it in for another pressure test, just not at a Barons. They are a waste of time and money.
Gti3
Post by Gti3 »
BKj wrote: Mon Sep 30, 2019 1:39 pm
Hi
Hi
Thanks again.
Glad you sorted!
2020 MK7.5 GTi DSG
EX:2010 MK6 GTI 6MT
EX:1993 Golf 3 Gti
