vehicle it cranks but it doesn't start
Have 1.6 polo vivo max battery was flat jump started it then it was fine , next day in the morning car swings but if doesn't wanna start tried jump start again nothing happened if swings battery powerful ,came back checked fuses ,relays, compression, timing belt everything is still fine but I took out a spark plugs dez no spark help please what can be the coarse of that
Re: vehicle it cranks but it doesn't start
Did you jumpstart with both jumper cables from other car direct to your battery? If so, you may have caused a spike voltage to the ecu. Best practice as per owners manual is to have positive on battery positive and negative from booster battery or car on your engine. Chances are that you have possibly popped the ecu.
Try removing the positive terminal from battery, leave it off for about 30 seconds and reconnect and try again.
It could also be your cars immobiliser causing this.
- Reegz
- Membership No: 1400
Welcome to the forum!
2016 Golf 7 Tyre Devourer
---- Ex ----
2008 Honda CBR 600RR - SOLD
1996 Citi Golf CTi - SOLD
---- Ex ----
- Neuk
- Treasurer
- Membership No: 806
Welcome and enjoy the forum I will move this post to a Technical section...
no spark can be anumber of things but basically start with a diagnostic scan and see if the management sees rpm.
