No oil pressure in jetta 4 slim line 1600 akl engin
Hi guys ,i have a jetta 4 slim line 1600 akl engin had the crank cut ,re-bored and new oil pump and i have started the motor starts well but there is no oil coming up ,i did a diagnostic and found oil only coming up till oil filter unit ,
question :
How to proceed from there?.any advise,please
no oil pressure
- Registered for: 7 years
- Car Model: JETTA MK3
Re: no oil pressure
oil filter is probably blocked , seems like that would be the logical explanation, get e new filter and ensure outlet of oil filter housing is open so oil can flow through, not familiar with the jetta 4 though, im just thinking out loud here
Audi A1 7 speed STron
auto Jazz 03
auto Jazz 03
Re: no oil pressure
HI thanks for tip did that ,sent oil cooling housing away that all clear next thought is to remove sump and fit oil cooling assembly and pour petrol down the oil pipe from top of block and hope that if there is a blockage that the petrol will clear that ,,,holding thumbs
