To retorque or not to retorque head bolts after 1000 kms.
mellos
Registered for: 7 years 9 months
Post by mellos »
Good day
I just want to find out if it is necessary to retorque head bolts after 1000 kms
and if it is needed what would the procedure be.
Some say to loosen the bolts a little and then retorque.
Thanks.....
Car Make: VW, VW, Aprilia
Re: To retorque or not to retorque head bolts after 1000 kms.
Post by Jetta2 »
What motor?
But generally, no need to retorque. Torque them once and leave them.be.
Terblanche
Registered for: 9 years 6 months
Post by Terblanche »
I haven't heard of head bolts that you have to retorque and they are normally TTY/stretch bolts and you can break them by tightening for a second time.
So if the workshop manual for your specific engine doesn't say you must retorque, then don't do it.
Rather replace the engine oil and filter after 1000km, after you worked inside the engine.
mellos
Post by mellos »
Jetta2 wrote: Thu May 03, 2018 10:07 pm What motor?
It is a Tazz 1300 12 valve.
mellos
Post by mellos »
Terblanche wrote: Fri May 04, 2018 2:37 am I haven't heard of head bolts that you have to retorque and they are normally TTY/stretch bolts and you can break them by tightening for a second time.
The cambelt broke so a rocker broke and bent 2 valves so we just replaced the rocker
and done all the valves so no other work done besides the head.
Rascal69
Registered for: 16 years
Car Model: MK1
Membership No: 1490
Post by Rascal69 »
If you followed the correct torque proceedure for that car then it should be ok... I remember doing a tazz with 4agze in november and for the head bolts it was something stupid like 40NM and then 90Degree and then another 90 degree and that was it... there was no requirement to retorque the head after 1000 km's..
Current: 2007 ///M Coupe
Current: 2019 Fortuner 4x4
Ex: 2005 E55 AMG
Ex: 1998 BMW M3
BIGMIG
Porra Love
Membership No: 1574
Post by BIGMIG »
From what i have researched the old non stretch bolts needed to be re torqued, the reason for manufactures using stretch bolts was to do away with this old method so that customers didn't have to come back to the dealer for this mundane task plus some other various reasons.
My NoPiel assassin
Goose, soot ninja
Pot kak. You can't retoque torque to yield bolts. Go kick the oke in the nuts that told you that.
BIGMIG
Porra Love
Membership No: 1574
Post by BIGMIG »
panic-mechanic wrote: Fri May 04, 2018 12:17 pm Pot kak. You can't retoque torque to yield bolts. Go kick the oke in the nuts that told you that.
Who are you referring too?
My NoPiel assassin
Goose, soot ninja
The oke that told the OP to retorque a TTY bolt.
ICE King
Post by ICE King »
What do you retorque it to if it's was already done initially? Never understood this retorque business
I'd understand if the bolt came lose but then that would mean something wrong with bolt(thread or stretched) or it wasn't done properly initially
Sounds like a phrase used for the 1000km checkup after a major engine repair
Anyways , I would just buy new bolts if the current bolts has done alot of mileage or was used more than once
BIGMIG
Porra Love
Membership No: 1574
Post by BIGMIG »
Ahhh yes I see. I keep telling people not to reuse stretch bolts but if they are in a pinch then they can be reused but only once. More then twice is a definite toss them away.
My NoPiel assassin
Goose, soot ninja
BIGMIG
Porra Love
Membership No: 1574
Post by BIGMIG »
Re-torquing deals with the NON STRETCH bolt after it has gone through its thermal cycles and vibrations.
My NoPiel assassin
Goose, soot ninja
ICE King
Post by ICE King »
Use a steel gasket , new TTY bolts and you wont have to retorque
They used crappy head gaskets back in the day
it' not that. Cast iron heads with non stretch bolts would change clamping force after a few heat cycles. Since Aluminium heads and TTY bolts there is no such thing as re-torque. No matter what head gasket material is used.
mellos
Post by mellos »
Thanks for the advice and input guys I guess this topic can be put
to bed now,maybe it can be added to the frequently asked questions
section.
Cheers.
