Where can I find the best VW Auto Electricians
I have a 2002 Golf 1.8 MK 4 with AGN 20V engine Non-turbo:
1. If you power on foglights the fuse is blown out.
2. Windows are not working properly e.g. sometimes they open and after a while they don't
3. Front door lights don't work. Bulbs ok and if you put earth to them they work.
4. Driver door doesn't activate alarm
5. Alarm speaker volume is very very low. You can only hear it if 2m or less
6. Central locking is on and off. Front passenger door is out on any activity.
7. Temperature controls don't light when lamp switch is on.
8. When you engage aircon fans don't engage
9. Interior lights sometimes on/off when the switch is put at door .
For the aircon I bought 2 modules. One is under the battery compartment one is behind glove box but still the fans don't engage but the car is cooling.
So where can I take this car for repair?
- Car Make: Isuzu
- Car Model: KB250 LE 2006
Re: Where can I find the best VW Auto Electricians
welcome to the forum ,
best tell us what area you are in ,sure one of the many members will point you in the right direction
I am in Gaborone, Botswana.
I can take this car anywhere I can get best results
- Zimbo
- Car Model: Golf 6R
Boksburg?!?! If you somehow get here I can help.BW1.8 wrote:I am in Gaborone, Botswana.
Motion Fitment Centre & Auto Electrical UNIT 9 12 Atlas RD Anderbolt Boksburg 0118943635 talk to Anton Meyer. Also a car nut of note.
Hi guys. I am also having an electric window problem with my mk5 build. Based in Pietermaritzburg but anywhere in kzn that you can recommend? Thanks
Thank you very much Sir. I will pass by you soonZimbo wrote:Boksburg?!?! If you somehow get here I can help.BW1.8 wrote:I am in Gaborone, Botswana.
Regards
I got it and thank you very much Sir. I will contact Anton today and take it from there. Thank you.MrMazda wrote:Motion Fitment Centre & Auto Electrical UNIT 9 12 Atlas RD Anderbolt Boksburg 0118943635 talk to Anton Meyer. Also a car nut of note.
Most of your issues sound likembad earthing though. So first have a good look at all the earth points.
Day All, where can i find VW Auto electrician in this location Silverton Pretoria
