How to get my headlights to work on a golf1
I checked the fuses , all fine ,
I changed the bulbs , all fine. ( my bright lights work,back lights and brake lights work , but not my normal headlights)
what else can i troubleshoot to get my head lights to work ? i have a chico golf
- WesleyE
- Car Model: VIVO
Re: How to get my headlights to work on a golf1
Shot in the dark , but have you checked the switch for the headlights?
“I couldn’t repair your brakes, so I made your horn louder.”
- Schpleegz
- Car Make: VDUB
Have you checked your fuses?
His - '90 Mk2 Golf GTi 1.8 8V
Hers - '13 Mk7 Golf GTi DSG
'89 Mk2 Golf GTi 1.8 16V
'04 Citi Golf 1.4i
'91 Mk2 Jetta CSX
'88 Citi Golf 1.3 (ice-cream)
'93 BMW E36 316i (Auto)
'05 Polo Classic 1.4i (Trendline)
'11 Polo 1.6tdi
'70 VW Beetle 1.6
'13 Ford Focus ST250
'90 BMW E30 320i
'04 Citi Golf 1.4i
'91 Mk2 Jetta CSX
'11 Polo 1.6tdi
'70 VW Beetle 1.6
'90 BMW E30 320i
- amstel18
- Car Model: Tiguan Allspace
Replace the headlight switch. Common problem
2022 GWM P-Series LT 4x4
2018 VW Tiguan Allspace
2006 Seat Ibiza Cupra TDI
96 1600 Chico (sold)
i changed the headlight switch , (goldwagen R110 ) problem still exist.
im going to change all the fuses , and if it dont help il go to an auto electrician
You need to trace where the power break is with a volt meter. Guessing and randomly replacing parts is is an expensive way to do it.
It can even be the ignition switch.
- Car Make: VW Golf 1
- Car Model: 2.0 h8 valve
Hi there, go and change your indictor lever on the left if you haven't already....What I mean is change the whole left lever that you use to indicate, I'm certain it will work...I went through that issue not so long ago and the above fix worked the charm....Good luck and let us know what is the outcome
Hi Guys
my wife has a 1997 mk1 citi (carb). We bassicly had the whole car redone and she looks and runs great but now suddenly the lights keep going off while driving. it seems to be the switch because when you touch it the lights come back on. i decided to replace the switch, when i phoned glodwagen they wanted to know whether it is a 2 or 4 pin switch and i have no ideas as i am not at all technically inclined and i dont want to have it taken out before i have to go buy it because my wife leaves home at six in the mornings and sice it is winter she cannot drive in the dark.... any advice on which it might be? 2 or 4 pin?
Pull the switch out the dash, pull the connector off and count how many pins it has.
Good day
I'm having a VW citi golf Tenacity 2009. My lighting problem is intermittent. At times the headlights fail to switch on after starting the car, it affects the indicators and fan blower motor as well. At times when i flick the brights on, it solves the problem(ONLY SOMETIMES) Other times i just need to try ...and ...try...and try....
It is becoming a real problem, because winter is coming and i'll be using the lights early in the morning. I already changed the headlight switch...but it didn't solve the problem.
Please help....ANYONE
- CharlDHechter
- Car Model: 1987 Mk2 2.0L 8v
This sounds like a problem between the ignition and a relay if it cuts off all of those components. Also check all the fuses.
My previous Golf 1 had lots of relay issues (wipers to be specific, ironic hey), there was water leaking over the fuse box.
