2.0 8v Conversion on a Mk1
- Car Model: Mk1 2.0l 8v
Hello everyone.. My name is Mohammed Taahir.. Mostly known as Moto... I'm from Joburg..
I have a 1980 golf mk1.. The car had a 1.8 carb motor but it was taken out before I bought it.. I bought a 2.0 8v motor and I wanna put it in the car but I dont know what must be changed on the car ? and what extras do I have to buy?
- AyaThatGuy
- Car Model: MK1 Golf
Re: 2.0 8v Conversion on a Mk1
Welcome to the forum bro.
Do you plan to keep the car carb or change to FI? If you plan to use injectors then you can just search there are plenty threads of how to do the change and the bits that you will need.
- Unobeat
- Registered for: 13 years
- Car Model: Uno, Auris, CX-5
Good question by Aya.
Chucker on the forum is running his Citi 2L 8v motor on Carb and has a bigger cam in.
Some reading: http://vwclub.co.za/forum/viewtopic.php ... conversion
- chucker02
- Car Model: Citi ADY
As unobeat said, I ran my old car off a carb and the power was good and fuel consumption was good, but FI is just so much better. Smoother, can be fine tuned alot more than a carb, more power
1971 VW beetle
1971 VW beetle
- Car Make: vw mk1 2l 8v
- Car Model: mk1
2l 8v fi best thing you can do by far, i have a mk1 92 model, recently put a 2l 8v motor running a ffz gearbox very very quick. wanna change the cam ( Maybe 288 ) any suggestions. or goodness, my name is Justin sorry guys
- AyaThatGuy
Are you using MP9 or aftermarket management? If MP9 then best stick to a 276 cam anything bigger than run management.Justin Jafta 26 wrote:2l 8v fi best thing you can do by far, i have a mk1 92 model, recently put a 2l 8v motor running a ffz gearbox very very quick. wanna change the cam ( Maybe 288 ) any suggestions. or goodness, my name is Justin sorry guys
Is your Mama YamaMoto ?moto767 wrote:Hello everyone.. My name is Mohammed Taahir.. Mostly known as Moto... I'm from Joburg..
Sorry, temptation was too strong.
Sent from my SM-N9005 using Tapatalk
hi guys just wanna find out i have 2001 vw citi life 1.6i. The motor seezed after overheating 3 times. i want to get a 2.0 8v ady engin for the car what needs to be done to do the conversion.
unbolt the 1.6. Service and change cambetl on the 2l. Bolt it in - possible get a bigger flywheel and clutch, get the mp9 mapped to a 2l box and off you go. there are 100's of build threads. Go look in the rides section.
thanks so basic is that the flywheel and the clutch and the computer box that needs to be remaped
- Unobeat
Yes yes yesStoepie999 wrote:thanks so basic is that the flywheel and the clutch and the computer box that needs to be remaped
Hey guys
I bought a AGG engin putted it in know the engin dont start. Any ideas were i can start looking for any problems. I had n AFX fuel injection engin in before. And i putted the intake of the AFX on.
the trigger wheel in the distrubutor only has one window. You need 4.
buy a complete dissy from GW.
thank it starts and the engin is good but have the problem of the car now is that the the doesnt idle right so i unpluged the altitude sensor on the intake now it sounds beter but its still not fine . Fuel consumption is bad .
did you do a remap. Did you set the IGNITION timing right?
- Registered for: 2 years 3 months
Hi guys Moe here busy building my mk1 want to change my 1.8 carb motor to 2.0 8v where can i shop around? Also i want to sell the 1.8 carb motor of which i have 2 sitting in my garage any idea where i can sell them off? Need the funds to buy the 2.0L 8v
Sorry forgot to mention im in jhb east rand
- Car Make: Ford
- Car Model: Focus ST
Sell them privately.There is always somebody looking for vw engines.Facebook marketplace is useful.Mk1 on steroids wrote: ↑Sun Jan 23, 2022 9:56 pm Hi guys Moe here busy building my mk1 want to change my 1.8 carb motor to 2.0 8v where can i shop around? Also i want to sell the 1.8 carb motor of which i have 2 sitting in my garage any idea where i can sell them off? Need the funds to buy the 2.0L 8v
2010 ST225 - 238kw 439nm
- Registered for: 2 years 2 months
hi guys i have a vw golf mk4 but boot dont lock and as for my doors the lock jumps up and down and while im driving the aarm goes on and then back off can any1 help in resolving this issue...thanks
- Registered for: 6 months
Morning Gents, I'm new here. I would also like to know what changes need to be done In order to fit a 2.0L 8V FI. I'm trying to buy one because I'm running a 1.3 Carb.
