Polo 9N3 Interior Trim Overhaul
- Legion739
- Car Model: A3 2.0T - K04
So I've been busy this weekend.
What started out with just replacing blown tail light and removing number plates so I can stick them on with valcro dots ended up being a lot more.
My center console was scratched quite bad and that rubber k@k wasn't looking to great so then this happened
Removed everything (cup holder popped open and was a **** !! to resemble)
Some pics of trying to polish of the rubber K@K lots of elbow grease needed
Where I realized there is no way in fark I'm getting the rubber k@k of nicely so I used 360 grit sandpaper and plastidip remover (basically thinners) to get it all off nicely
Morné doing so spray work, we used quick dry matt white spray paint
And here's the end result
Go check out my rides thread for more --> http://www.vwclub.co.za/forum/viewtopic ... 6#p2282886
- Jacques1397
- Car Model: Citi Rox 1.4i & Golf 5 GTI
- Membership No: 1970
Re: Polo 9N3 Interior Trim Overhaul
Had the same to do list a while back. Went for matt silver as it matches the original color of the GTI. Need to do it over again. Is it just me or pics not working ?
Current :
2007 Golf 5 GTI
2008 Citi Rox 1.4i - Daily
Ex :
2009 Polo 1.8t GTI Stage 2
2007 Golf 5 GTI
Ex :
- Legion739
awesome, when I get my side skirts sprayed I'll have those interior timings done professionally, everything looks perfect but I'm just scared it will get dirty.Jacques1397 wrote:Had the same to do list a while back. Went for matt silver as it matches the original color of the GTI. Need to do it over again. Is it just me or pics not working ?
Looks like mine works fine ? use http://imgur.com/ to upload pics
- J0NN0
- Moderator
- Car Make: No Name
- Car Model: Tekkies
- Membership No: 1725
looks great! I dig it
Jonno
2002 Volkswagen Lupo 1.4TDI - SAC: 87.7 kw 276.1nm
2018 Mitsubishi Triton 2.4 D/C 4x4
2006 Mitsubishi Colt Clubcab 2800 TDI
2003 Volkswagen Lupo 1.4 16v Auto
2007 SEAT LEON FR
1983 Volkswagen Caddy - Panic: 319.7hp 360nm
2008 SEAT LEON CUPRA - Oettinger: 191kw 352nm
2008 SEAT IBIZA CUPRA - HM Auto: 146.9hp 244nm
2007 SEAT LEON FR - KAR: 163.2kw 337nm
2007 Volkswagen Polo 1.6
2001 Ford Fiesta Flite 1.4i
VWCSA Membership Number: 1725
2007 SEAT LEON FR
- quintinm
- Car Model: Fox (jetta 1)
That white really looks nice... well done
- Shivbeanz
- Car Model: 9n Sportline
Looks good! very storm trooper like
Any tips for removing the dash and cup holder?
(Oo=o=oO)
- Car Model: A3 1.8TFSI 8P
Looking good bru... considering this after I saw your pics
If you aint first, your last !!!
- Legion739
Thx guys
How to remove center console:
1) RED: Just pull off (use a screw driver if needed but I got it off by hand) Then there are 2 screws you need to remove behind it
2) GREEN: Just pull off (use a screw driver if needed but I got it off by hand) Then there are 2 screws you need to remove under it
3) Remove your radio or what ever you have there, there are 2 screw behind your radio that needs to be removed.
4) Then comes the tricky part, removing the "Card holder" is easy (pop it out with a screwdriver) then behind it is 1 screw also holding the center console. the hard part is removing the damn cup holder, there is one last screw behind it holding the center console.
The cup holder has 3 clips holding it (one of which you can't reach) I got mine out by pulling the whole thing apart from the front so that I can get to that screw and resembled the cup holder later (not easy if you didn't keep track of which parts go where).
I know you can also get it out with applying lots of force on it from the back, but you might break a clip (not the end of the world) my advice would be to go watch a couple of youtube videos on how to remove the cup holder
After that it's cake the whole thing just comes off easily, the searing wheel bits and vents also just pop out with a screw driver
Tip: don't want to scratch the plastic with a screwdriver ? just stick a layer or 2 of insulation tape over the screw driver
Now for that rubber K@K !! it's really a **** to get off especially if you want to get if off without making any small scratches on the plastic, I did about 10% of it perfectly with a cloth and scraping at the rubber with plastic tools, after a hour and a half I got sick of it and took plastidip remover (basically weak thinners) and 360 grit sandpaper and it works like a charm !! and will provide more grip for the paint to stick to.
Then we got some Quick dry matt white spray paint and gave it all about 5 cotes and It all came out looking great in the end
It's quite simple removing everything that I sprayed whiteShivbeanz wrote:Looks good! very storm trooper like
- PoloGirl
- Car Model: 9n3 Polo 1.4 2006
- Membership No: 1842
Looks good bud! As you say it is a b!tch to remove the cupholder. I just pulled mine out with some force. It came apart. But was easy to reassemble it onces its out.
'06 1.4i 9n3 PoHi
Previous ride:
'94 1.3 Citi Golf stock
TA-Technix coilovers
all improvements done by a girl
Previous ride:
- Legion739
Nice !! mine wasn't Everything poped appart and jumped all over so we had no idea how to put it back togetherPoloGirl wrote:Looks godd bud! As you say the cup holder is a b!tch to remove the cupholder. I jist pulled mine out with some force. It came apart. But was easy to reassemble it onces its out.
- PoloGirl
You can ask anytime if you need help bud. Just not engine stuff lol
'06 1.4i 9n3 PoHi
Previous ride:
Previous ride:
- Jacques1397
Good Write up on the removal part.
I have to say , the 9n3 is an easy car to work on. I replaced my complete dashboard and trim a few months ago and managed to put everything back as well. No rattles at all. Very easy. Will take you maybe some time in the beginning to strip but you learn the ropes fast.
Current :
2007 Golf 5 GTI
Ex :
2007 Golf 5 GTI
Ex :
- quintinm
Its because men always complicate things..... wait or is it supposed to be the other way round?Legion739 wrote:Nice !! mine wasn't Everything poped appart and jumped all over so we had no idea how to put it back togetherPoloGirl wrote:Looks godd bud! As you say the cup holder is a b!tch to remove the cupholder. I jist pulled mine out with some force. It came apart. But was easy to reassemble it onces its out.
- Nishp
- Registered for: 9 years 4 months
- Car Model: Mk4 GTi, VivoMaxx
thats the sweetest bit of mod that ive seen in a while. nice contrasts.
i wonder why it does not come from the vw factory like this.
good job man and
thanks for some inspiration.
good job man and
Mk4 Golf 20V Turbo Fanatic.
- Reegz
- Membership No: 1400
Very cool!
2016 Golf 7 Tyre Devourer
---- Ex ----
2008 Honda CBR 600RR - SOLD
1996 Citi Golf CTi - SOLD
---- Ex ----
- Silverbird_96Kw
- Car Model: Mk7 Golf R
- Membership No: 1643
Nee to follow this. Want to take it apart and maki it Vloss black and mYbe i can also sort out the rattles there same time
15 VW Golf R
15 VW Passat 2.0TSi Rline
17 VW Polo 1.2TSi Highline
17 VW Golf Mk7.5 GTi
15 Audi A3 Sedan 1.8TFSI Stronic
11 VW Roc 2.0TFSI DSG
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
12 VW Golf 6 1.4 TSI Comfortline
06 Vw Polo 1.9 TDI Sportline
15 VW Golf R
06 Audi A3 2.0T
08 BMW E90 320D
10 Audi A3 1.8T FSI
