Pistons
- Car Model: Fox
Pistons
Hi guys just need some help on brands of pistons that are good but not to expensive lol. I'm havin my engine rebuilt. The engine is being bored to 40thou now. I would love KS pistons but they are like hens teeth lol. Do you guys know of other brands i can use that are good. The car is going to be used everyday and occasional long trips.
- Car Make: Ford
- Car Model: Focus ST
- General
- Registered for: 18 years
- Car Model: Golf GT
- Membership No: 1464
Re: Pistons
Hi, what engine is it - I've got a set of brand new 83mm KS 2E pistons with rings that I might be persuaded to sell to you...Nazeem wrote:Hi guys just need some help on brands of pistons that are good but not to expensive lol. I'm havin my engine rebuilt. The engine is being bored to 40thou now. I would love KS pistons but they are like hens teeth lol. Do you guys know of other brands i can use that are good. The car is going to be used everyday and occasional long trips.
Current rides:
Hyundai - 1.4 Getz (daily)
- Car Model: Fox
Re: Pistons
1800 HV engine
- General
Re: Pistons
OK then those won't work - you going 1900?Nazeem wrote:1800 HV engine
Current rides:
- BongzThaMr_K
- Car Make: Polo
- Car Model: Vivo
Re: Pistons
Arias or Wiseco
I'm argumentative, uncompromising and Emotionally-distant. Being with me's a war of attrition...
That's what winning the war gets you! *Remisces to my days in Vietnam*... *Sheds a Tear*
Previous Car: Toyota Tazz 160
Current Car: Polo Vivo 1.4 With Ridiculous Bass from the Boot
- Car Model: Fox
Re: Pistons
Wiseco is out of my reach lol.
- Car Model: Fox
Re: Pistons
I have no idea of any specs lolTorker wrote:OK then those won't work - you going 1900?Nazeem wrote:1800 HV engine
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
Re: Pistons
AE pistons or autopower for n/a
- Car Model: Fox
Re: Pistons
I got a suggestion of using a 2.5 Kombi piston. If i go with the suggestion will it work with the HV motor. Seeing that the engine is being bored to 40thou do i ask for a 40thou Kombi piston? Or how are the standard size pistons compared to each other between the 1800 HV motor and 2.5 Kombi motor?
- Car Model: Fox
Re: Pistons
So you say those brands will work just fine? And they can take a punch .Naku786 wrote:AE pistons or autopower for n/a
- General
Re: Pistons
Stock 1800 piston is 81mm so 40 thou over is 82mm. Stock Kombi piston is 82.5mm but you can also go 40 thou over to 83.5mm. The 2.3 Kombi piston will work with the 1800 crank, with 83.5mm pistons it will give you the magical 1900 motor.Nazeem wrote:I got a suggestion of using a 2.5 Kombi piston. If i go with the suggestion will it work with the HV motor. Seeing that the engine is being bored to 40thou do i ask for a 40thou Kombi piston? Or how are the standard size pistons compared to each other between the 1800 HV motor and 2.5 Kombi motor?
Current rides:
Re: Pistons
Kombi 2.5 piston will need a new crank to make them work. A 2l crank that is. If budget is an issue stick with the 40 thou (1mm) o/s pistons. All the stock parts will work the way they supposed to
- Registered for: 11 years
- Car Make: Chevy
- Car Model: Sonic 1.6 LS B&W
Re: Pistons
And so it begins....the magical 1900.
- Car Make: Chevy
Re: Pistons
Just to be technical, what is the displacement after going 1mm o/s?missioner wrote:Kombi 2.5 piston will need a new crank to make them work. A 2l crank that is. If budget is an issue stick with the 40 thou (1mm) o/s pistons. All the stock parts will work the way they supposed to
Re: Pistons
King8v wrote:And so it begins....the magical 1900.
Lolololololololololol
- General
Re: Pistons
Stock displacement is 1781cc, 40 thou over stock (82mm) will give 1825cc, 83.5mm Kombi will give 1893cc's.King8v wrote:Just to be technical, what is the displacement after going 1mm o/s?missioner wrote:Kombi 2.5 piston will need a new crank to make them work. A 2l crank that is. If budget is an issue stick with the 40 thou (1mm) o/s pistons. All the stock parts will work the way they supposed to
Current rides:
- Car Model: Fox
Re: Pistons
So which Kombi piston will work with what i got now? Crank is being cut to 20thou
- General
Re: Pistons
2.3 Kombi pistons...Nazeem wrote:So which Kombi piston will work with what i got now? Crank is being cut to 20thou
Current rides:
Re: Pistons
If you go that route like i did don't forget the 2.3 pistons will need about 1.5mm cut off the top to work and you will need a headgasket that suits your new bore size. Stock 1.8 gasket won't fit it will touch the pistons. It only has a diameter of 82.5mm. A 2E gasket is needed. You will also have to buy the 2.3 pistons 40 thou oversize to get 83.5mm. Stock is 82.5mm
- Car Model: Fox
Re: Pistons
Is it worthwhile going the Kombi piston route?Will there a notable difference in power ? Or must I just go with the standard oversize pistons.
- General
Re: Pistons
A well sorted 1900 will give most 2.0's a hiding (Viper's Golf is a good example). Why it's so popular, the big bore/short stroke ratio give it the ability to rev like no stock motor can...Nazeem wrote:Is it worthwhile going the Kombi piston route?Will there a notable difference in power ? Or must I just go with the standard oversize pistons.
Current rides:
- Car Model: Fox
Re: Pistons
But im doing nothing to the cylinder head.Will there still be an increase in power?Torker wrote:A well sorted 1900 will give most 2.0's a hiding (Viper's Golf is a good example). Why it's so popular, the big bore/short stroke ratio give it the ability to rev like no stock motor can...Nazeem wrote:Is it worthwhile going the Kombi piston route?Will there a notable difference in power ? Or must I just go with the standard oversize pistons.
- General
Re: Pistons
Don't underestimate the increase in power from increasing the displacement, I've owned three 2.1 stroker motors and in all three cases that extra 100cc's made between 20 and 25Nm more on the Dyno than similarly worked 2.0 engines.Nazeem wrote:But im doing nothing to the cylinder head.Will there still be an increase in power?Torker wrote:A well sorted 1900 will give most 2.0's a hiding (Viper's Golf is a good example). Why it's so popular, the big bore/short stroke ratio give it the ability to rev like no stock motor can...Nazeem wrote:Is it worthwhile going the Kombi piston route?Will there a notable difference in power ? Or must I just go with the standard oversize pistons.
Current rides:
