golf mk1 doesn't want to start
imoparker
Wheel Whore
Car Model: MK1 2.0 carb
Post by imoparker »
It started about 2 weeks ago. I put the key into the ignition and swung but only the interior lights came on but no sound from the starter. I then pushed/forced the key into the ignition and then swung and the car started. It worked for like 2 weeks but now that doesnt work anymore. Now i must kick start. Car has new battery and alternator.
What could it be? bushes on starter?
thanks
Rienz87
Registered for: 10 years 9 months
Car Model: 2007 citi golf 2.0i
Re: golf mk1 doesn't want to start
Post by Rienz87 »
Hi there.
What model is it? I've had the problem that the main fuses next to the battery lightly corrode. This causes the car not to start and most of the components throughout the vehicle isn't working properly, even not at all. Just take sanding paper and sand the contacts, and slightly bend then scue.
R!3nz87
ShafiqNC
Car Model: Golf 6.:R
Post by ShafiqNC »
imoparker wrote:It started about 2 weeks ago. I put the key into the ignition and swung but only the interior lights came on but no sound from the starter. I then pushed/forced the key into the ignition and then swung and the car started. It worked for like 2 weeks but now that doesnt work anymore. Now i must kick start. Car has new battery and alternator.
thanks
just bridge the starter..wire from Bat. Positive to the thinner wire on your solenoid..note to have car in NEUTRAL!!!!!IF it starts then, then I would imagine your ignition insert or barrel could be stuffed.esp. If u say u forced key and it then started
vw is the best, f*#k the rest!!!
My Citi build!
tamper_man
Car Make: Jaguar
Car Model: X-Type 2.2D
Post by tamper_man »
ShafiqNC wrote:just bridge the starter..wire from Bat. Positive to the thinner wire on your solenoid..note to have car in NEUTRAL!!!!!IF it starts then, then I would imagine your ignition insert or barrel could be stuffed.esp. If u say u forced key and it then started
Sounds like the ignition switch.
Current: Jaguar X-type 2.2D
Ex: 2000 Citi 1.3
Insanetec
Car Make: VW,BMW,HONDA
Car Model: 1600 chico,120D,1600vtec
Post by Insanetec »
+1 ignition switch
current cars
06 Golf 5 Gti
06 BMW 320D MSport E90
14 BMW 316i F30
ex cars
95 Polo 1.9tdi Sportline 9N
BMW X3 Family ride
1.6 chico + VAT
Audi S3 Stronic
BMW 120d
97 civic vtec
02 golf iv GTi
98 civic vtec..... awesome power
93 cti
90 toyota corolla 1.6g
King8v
Registered for: 11 years
Car Make: Chevy
Car Model: Sonic 1.6 LS B&W
Post by King8v »
I bust my ingnition without even trying! swung too hard i think, but they wear out after as while.
imoparker
Wheel Whore
Post by imoparker »
thanks for the advice guys. I will replace the ignition switch and keep you posted
imoparker
Wheel Whore
Post by imoparker »
Ok.......I replaced the ignition switch and the starter is still not kicking in
I looked at the connection to the starter and noticed that there is only one connection from the battery to the starter.....is that correct?
Can someone please post a pic of the connections to the starter?
thanks
UDC
Membership No: 1041
Post by UDC »
thick positive from battery to starter solenoid +
thin red/black wire to solenoid pin from ignition
Saliegh07
Registered for: 2 years 6 months
Post by Saliegh07 »
:type: HI all, so my mk1 doesn't want to start from inside by turning the the key. If I start it outside by the starter, whilst the ignition lead is connected straight to the battery it starts first time. But the moment I try to swing from the inside it will just crank. Please help!
UDC
Membership No: 1041
Post by UDC »
remove ignition switch and try to start from the switch using a flat screw driver, if it works then its the ignition switch thats faulty, if not then you need to add a relay to that ignition circuit at the starter end
Saliegh07
Post by Saliegh07 »
When I turn the key, the ignition goes on and it cranks but doest start. When I connect the ignition wire to the battery it starts, but even if the ignition is directly on the battery and I put the ignition on with the key it doesn't take.
UDC
Membership No: 1041
Post by UDC »
If you turn the ignition and it cranks then its not the ignition switch.....is it cranking when you try to start with key or just makes a tuk, tuk sound like a dead battery
berry
Registered for: 9 years 1 month
Car Model: mk1 16V
Post by berry »
UDC wrote: Wed Sep 22, 2021 3:27 pm remove ignition switch and try to start from the switch using a flat screw driver, if it works then its the ignition switch thats faulty, if not then you need to add a relay to that ignition circuit at the starter end
How to do this?...on which wires do u connect the relay?
