No, shocks, unless the lower mounting position of the spring changes, do not determine ride height...LoW n SloW wrote:obviously a new shock would be higher coz its new, old shock had adapted and wore out thus started sitting on the height which u are used to
Citi Golf Higher After Fitting New Shocks
- Neuk
- Treasurer
- Membership No: 806
Re: Citi Golf Higher After Fitting New Shocks
- Evilsheepclone47
- Car Make: Seat
- Car Model: Ibiza 1.6i
Unless the shock is physically shorter in length like Gabriel Shortened Gas Rider? Right
Ride thread
06 1.4i citi - http://vwclub.co.za/forum/viewtopic.php?f=11&t=122072 - Sold
08 1.6i auris - http://vwclub.co.za/forum/viewtopic.php?f=11&t=177382 - Written off
08 1.6i ibiza - http://vwclub.co.za/forum/viewtopic.php?f=11&t=183191 - Current
- Neuk
- Treasurer
I presume that shortened shocks will have different mounting positions for the spring?Evilsheepclone47 wrote:Unless the shock is physically shorter in length like Gabriel Shortened Gas Rider? Right
Anyone here still on this topic? I've got this problem fitted new shocks all around to my Chico 1.3 but the rear is extremely high part number on Monroe shocks match and everything what could be causing the rear to be so high
If the shock supplied is correct.... . Then Then spring rest plate that fits on the shock, might be the wrong way around.
This plate is usually not supplied with a new shock and is taken of the old shock
