Citi Golf Higher After Fitting New Shocks
- Herschel
- Car Model: G6 GTI & CiTi Golf
Hi
I recently fitted new rear shocks on my CiTi Golf.I have a N-Force 60/40 drop,but after fitting the new rear shocks,the car is quite a bit higher than it was before.
It's the 1st time i come across something like this.
Has anyone had this problem before?
2011 Golf MK6 GTI DSG
Stage 2 Stealth Tuned
- Bullet03
- Car Model: MK2
- Membership No: 1821
Re: Citi Golf Higher After Fitting New Shocks
Hi bud, as far as I know u get 2 different shocks at the rear, the base where the coil spring fits in to is at different positions
1990 Developments
BURNING RUBBER
Membership number : 1821
- 1989 CITI Golf akaPAMPOEN
*Ornament
- 1985 Mk2 16v
*Watch this space
- 2001 Opel Corsa GSI
- 2008 Honda CBR 125
- 2007 Yamaha R6
- 2008 Nissan champ
BURNING RUBBER
*Ornament
- 1985 Mk2 16v
*Watch this space
- 2007 Yamaha R6
- 2008 Nissan champ
- Herschel
I measured the new shocks with the old ones & everything is exactly the same.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
did you replace bumpstops?
if you did then cut new ones in half...
- Herschel
No,I used the old bump stops.
- Cake Laaitie Killer
- Car Model: Citi 1.9i 8v
give it some time to settle
- Wheelwore
- Car Model: MK1 Velociti 1.6i
give it time bud.....
2007 - Velociti 2.0 ABF Black Magic
2008 - Velociti 1.4i Midnight Blue
2002 - Chico 1.4i White - Chicolux
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
- Car Model: Polo 1.2 TSI
Its the Base plate issue
Had the same problem and had to get shocks from VW direct.
The base plate on new shock is higher pushing the car higher.
Current: 1.2 Polo TSI 66KW
EX Polo Vivo Blueline
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
First I am hearing of this...Little D wrote:Its the Base plate issue
- Stompie
- Boostleak Guru
- Car Make: BMW
- Car Model: 2006 120D
- Membership No: 1843
a while back there was another guy also with a citi with the same problem. actually looked like they lifted the car higher...looked like a 4x4
- Wheelwore
cut 2 Loops......runs and hides
1996 - VR6 2.8 Golf
1996 - VR6 2.8 Golf
Wheelwore wrote:cut 2 Loops......runs and hides
- Killerwatt
- Car Make: AUDI
- Car Model: S3
What did you measure exactly? the overall lenght or the distance from the lower mounting point to the spring seat?
- Herschel
I measured the shock,the shaft length as well as the section where the base plate sits.Killerwatt wrote:What did you measure exactly? the overall lenght or the distance from the lower mounting point to the spring seat?
- Delokes
- Car Make: Vw , Bmw
- Car Model: Mk1 CTi Turbo , 318ti
makes me think of Raaiz that drove the yellow golf with now springs at all LOKL!!!!Wheelwore wrote:give it time bud.....
- Colonel
- Membership No: 1041
old citi spring in the middle, with higher spring seat on shock as compared to newer type
old vs new, same spring
there is the problem
You can see how high the base plate sits
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
EX VeloCiti 1.4i
40mm H&R Drop.
17' SSW Mag Wheels.
- Neuk
- Treasurer
- Membership No: 806
Seems pretty obvious to me...
- Herschel
Yeah,but i checked that when i installed the shock.I even removed it again to double check that the base plate sections are the same.
- Membership No: 2033
you maybe flip the base plate over? that will lift it a bit?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
- Le Clue
- Membership No: 1458
Dude, you can clearly see the new shocks have I higher mounted base plate than the old ones. You got the wrong shocks, that's it.
Previous Rides:
2011 VW Golf Mk6 R
2007 VW Golf Mk5 GTI
2013 VW Polo 6R GTI
2011 VW Scirocco GT 2.0TSI
2010 VW Golf Mk6 GTI
2007 VW Polo 1.9TDI Sportline
2009 VW CitiRox 1.6i
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- graham savage
- Colonel
- Membership No: 803
Of course they are high, you're in cape town
obviously a new shock would be higher coz its new, old shock had adapted and wore out thus started sitting on the height which u are used to
2001 'rolla 160 gle (ex)
2005 old schooled caddy (ex)
1995 vw golf 1 ((ex)
- Le Clue
Is this amateur hour?
It won't sit like a 4x4 with the correct shocks. Once driven in you'll maybe be 2mm lower that's it.
Previous Rides:
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
2011 VW Golf Mk6 R
2013 VW Polo 6R GTI
- Evilsheepclone47
- Car Make: Seat
- Car Model: Ibiza 1.6i
Uh I still don't get it??
Why'd they look different to each other?
Wrong shocks?
Wrong shocks?
Ride thread
06 1.4i citi - http://vwclub.co.za/forum/viewtopic.php?f=11&t=122072 - Sold
08 1.6i auris - http://vwclub.co.za/forum/viewtopic.php?f=11&t=177382 - Written off
08 1.6i ibiza - http://vwclub.co.za/forum/viewtopic.php?f=11&t=183191 - Current
