Recommend me a battery for the polo please
So I think the battery on the polo is on its way out. The car would not start yesterday morning. Push started it and drove to work (14km's). Went down to the car about 2 hours later and checked it started first time. Went out at lunch and drove about 8km's before parking off again until the afternoon. Car started and drove the 14km back to home.
Last night I had to move the car out the garage at about 20:00 and she would not start. Push started again this morning and she ran to work fine.
Is there a way to 'save' the battery before replacing it (i.e. place on trickle charge overnight?)
If I am to replace it, which brand would you recommend and are there any to stay away from?
Also, do I go with something with more cranking power given that I am running the ADY in the polo (and I have some sound in the car if that makes a difference).
Any advice would be welcomes as I am admittedly quite dof when it comes to batteries. :oops:
Thanks in advance.
ScottiesKJ
Registered for: 12 years 4 months
Car Model: 92 Citi Golf
Membership No: 1144
Re: Recommend me a battery for the polo please
Post by ScottiesKJ »
Lawrence is the battery one that still has the screw off bits so you can fill with water or a sealed unit?
If you can open it. check the water levels make sure its not low. if it is. top up with distilled water and give the car a charge or a good run
normally this will save it but chances are you gonna need a new one
I just got a Delco for mine also running ADY with Sound its a 452 i think will double check.
Current 2L 8V Citi Golf - Under Construction
Solo786
Car Make: Porsche,BMW,VW
Membership No: 1251
Post by Solo786 »
Have you checked that the alternator is charging the battery properly?
How do I do that? :oops:
ScottiesKJ
Membership No: 1144
do you have a multi meter?
Velofox
Car Model: '94 FoxT 2.0 16v'
Membership No: 1314
Post by Velofox »
duracell
Current Rides
1994 2.0 16v FoxT - Lexy
1998 2.0 8v Mk3 GTI - Liesy
My Inspiration
16vT Engine Pics
Image Image Image Image
Velofox wrote:duracell
:lol: :lol: :lol: :lol:
:tosser:
:moon:
ScottiesKJ
Membership No: 1144
Turn OFF all lamps and electrical components.
Place the vehicle in transmission range NEUTRAL and apply the parking brake.
Carry out the Load Test and No-Load Test.
Switch the Battery Tester to the ammeter function.
Connect the positive and negative leads of the Battery Tester to the corresponding battery terminals.
Connect the current probe to the alternator B+ output lead.
With the engine running at 2000 rpm alternator output should be greater than as shown on the graph.
Switch the Battery Tester to the voltmeter function.
Connect the voltmeter positive lead to the alternator B+ terminal and the negative lead to ground.
Turn all electrical accessories off.
With the engine running at 2,000 rpm, check the alternator output voltage. The voltage should be between 13.0 and 15.0 volts.
There we go my son. may the volts be with you.
ScottiesKJ
Membership No: 1144
PS if you don't have a meter to test with. sms me im in durban tomorrow evening eyes can comes helps you china. :hug:
Solo786
Membership No: 1251
Post by Solo786 »
First get a voltmeter,
Then do a battery test.
1)Connect the voltmeter directly across the "Battery Terminals". (NOT to the Cable Clamps)
2) While watching the meter, Start the Car.
3) The Battery Voltage should Never fall below about 10 Volts.
If it does:
a) The battery is either "Low in Charge".
b) Or The Battery is "Low in Water".
c) Or The battery has a "High Internal Resistance".(Possibly Sulfided Plates and probably Time for New Battery?)
Repeat This Test BUT:
1) Connect the voltmeter directly across the "Battery Clamps on the Battery Cables".
2) This Reading should be Within 0.1 Volt Maximum, the Same as 3 Above.
***If NOT, Clean Battery Terminals and Clamps.
2a)If Necessary, Repeat Test to Varify it is now OK.
Repeat This Test Again, BUT:
1) Connect the Voltmeter Directly Across the Positive Terminal of the Starter and it Case Ground.
2) If the voltmeter reading is More than 1/2 Volts Lower than the Previous Test,
You Probably have a Cable or Connector Problem!
Check the Connections between the Cable and the Cable Connectors. ON BOTH ENDS.
Alternator Test:
1) Start Car and run at a normal idle.
2) Connect a Voltmeter Directly Across the battery Terminals.
3) Turn on Headlights to High Beam.
4) check the battery Voltage.
The Battery voltage Should read between about 13.8 to 14.2 volts. (Possibly up to 14.5 Volts.)
5) Increase motor speed to about 1500 RPM. The Alternator should now produce a battery voltage between 14.2 and 14.6 Volts.
If it is Lower than 14.2 volts, the Alternator probably is suspect.
6) Now, Maintain the 1500 RPM and Turn off the Headlights. Run this test for One Full Minute.
"The Battery Voltage should NEVER Exceed about 14.8 Volts".
If it Does, the Alternators Voltage Regulator is probably Faulty, over charging the Battery
^^^ thanks bud!!!!
PoloRox
Car Model: 9n3 Comfortline ROX
Post by PoloRox »
if u replace stay very far away from SABAT batteries...
Ride Thread...
POLOROX...
FK Streetline COILOVERS
18" BBS LM REPS
HID 6000k HEAD+FOGS
Sony HU+ STARSOUND AMP+ PIONEER SUB
GLOSS BLACK CUPRA LIP.
Ex: VW CitiRox _Reflex Silver
Killerwatt
Car Model: S3
Post by Killerwatt »
If you do havta get a battery, look into either a deltec/varta from deltecpower in pinetown.
willard/exide/sabat and all the others are the same battery in a different box with one year warenteys.
the varta/deltec have a 2 year warentey.
Solo786
Membership No: 1251
Post by Solo786 »
varta ftw!
Thanks for the info.
Now in terms of the size/power of the battery - should I stick with the size I have (same battery that was used in the 1.4 before I put the 2l in) or should I get something bigger/stronger?
SHAUN
Registered for: 19 years 8 months
Car Model: 2006 335i
Membership No: 1148
Post by SHAUN »
lawrence wrote:Thanks for the info.
What is your current batt size? I had a 658 in my polo and it did the job very well, a little bit doesn't harm anyone.
2006 E92 335i * Monica
1991 MKII GTI - Sold
1989 MKII CSL - Sold
Solo786
Membership No: 1251
Post by Solo786 »
unless you're running some hectic sound system, i dont see the need for you to fit a bigger battery.
:hi: Shaun
Current battery is a 628
Tdi jetta 4 ever
Post by Tdi jetta 4 ever »
Get a maintenance free battery.
Robin
robinwisse@gmail.com
zane.mk1
Car Model: Audi RS3
Post by zane.mk1 »
:hi: Shaun
Sounds like your battery is on the way out. My car made the same and just replaced the battery.
Firstly, check battery water.
If your problem persists, get the battery checked at a battery center.
If battery is dead. Get yourself a 628 Sabat Silver Calcium maintenance free battery. Cost roughly R780.
His: '18 Nardo Grey Audi RS3
Hers: '19 VW T-Cross 1.0 TSI Highline DSG
Weekender: 'Searching for a neat enough VR6...
Junzo
Registered for: 4 years 1 month
Post by Junzo »
Can i use a 44ah battery on a polo 1.2 tsi?
Car Make: VW, VW, Aprilia
Post by Jetta2 »
Junzo wrote: Thu Oct 21, 2021 7:00 pm Hi
A Google search says the minimum Ah for that car is 60Ah, so short answer is no.
spdgti
Post by spdgti »
Solo786 wrote: Wed May 16, 2012 1:36 pmvarta ftw!
:iagree:
'08 06 Magma Orange Cross Polo
ex: Reflex Silver GTi-R
Car Make: Fiat, Toyota, Mazda
Car Model: Uno, Auris, CX-5
Post by Unobeat »
spdgti wrote: Wed Oct 27, 2021 10:58 pm
:iagree:
Triple agree
I love Varta batteries.
