Fixed.1FlyTDI! wrote:Thanx for the advice marco !! I learn something new each day .... I heart this forrim
Pleasure. I also learn something new here every day.
How would you get in there without taking of the wheel ?? 18's is big bro !!!!Tander wrote:Rather replace both while you at it bud. I made the mistake of just replacing one (Left side) and issue was still there. Replaced right side and no more noise!
Try taking the bolts out of the con links (drop links) before jacking the car up - makes life easier this way. Also you can fit and remove them without taking the wheel off. And don't take the car all the way up - just enough to loosen the drop link from the two bolts. It pops off easy like this..
15 mins per side and you done!
No problem bud !! Thanx for the helpTander wrote:Oh in that case take the wheel off - lol
I have stock 15's - so there is plenty room. My bad!
Tander wrote:Decent price. Loving the silence now!
Let us know how you get on
Yes I did tighten them propperly ......... The new noise is comming more from the middle and not where the conlinks is situatedTander wrote:Did you tighten bolts properly and while the car was on the jack?
Its quieter out of gear then i can hear it ...... smooth surface buddyTander wrote:While you're in gear, too or only out of gear? also - over smooth roads or only bumpy roads?
Replaced LCA bushes recently?1FlyTDI! wrote:The noise is still there bro Im not sure whats going on .....
Will have to take the car to someone who can check for me
Om hom uit te kry is flokkol teenoor om hom terug in te kry op Coilies!!!Scatman wrote:Also to add:
I've noticed that these drop links are real buggers to get out of the strut... One way of getting them out more easily is to get someone to turn the cars' wheels so that the drop link just pops out. Might save someone out there some frustration
Neuk wrote:A pole, doth not a lie tell...
To check if LCA bushes are wacked, park car, try to roll the front wheel forward and backwards with your hands. It should be stiff and in place. If it has excessive play, replace bushes.Tander wrote:Replaced LCA bushes recently?1FlyTDI! wrote:The noise is still there bro Im not sure whats going on .....
In that case my bushes is still fine .....DarkRanger wrote:To check if LCA bushes are wacked, park car, try to roll the front wheel forward and backwards with your hands. It should be stiff and in place. If it has excessive play, replace bushes.Tander wrote:Replaced LCA bushes recently?1FlyTDI! wrote:The noise is still there bro Im not sure whats going on .....
Cant seem to access the link bro ??1.9TurboVw wrote:so i also replaced my conlink, the noise is alot less but im still getting the same noise at times so it must be something else too..
i did notice the ball guide joint looks a little bent, is that normal?
not sure if its called the ball guide joint but its number 5 in the link below
http://www.wagenstad.com/index.php?modi ... e=4-407-10
has anyone changed this before?
please help
So I got my car fixed today ..... When you tighten the bolt on the stabalizer , theres a screw inside of the bolt that you need to tighten aswell to secure it1FlyTDI! wrote:The noise is still there bro Im not sure whats going on .....
get the drop links from GW and fit it yourself doesnt take too long and its only 2 bolts and remember to tighten the two screws as wellGTI 2 POLO 2.0 wrote:Hi Guy's
Picking up the same noise on my polo
Does anybody knw of any mechanics /Garage that i can take it to get it checked up.
Did take it to a couple of guys but they couldnt figure out wat it is.
Mechanic in Durban??????
Tander wrote:I never tighten that screw - I just made sure the bolts were tight...
Hope you come right 1.9TurboVw
