Polo knocking noise suspension Droplinks/Conlinks *DIY fix*
- Tander
- Registered for: 15 years
- Car Make: Seat
- Car Model: Leon Cupra
- Membership No: 1713
Howzit guys,
So I got new LCA bushes fitted by Morne (G60 golf) (Nice guy and very helpful!)
Now I asked him to look at the rest of the car while he was fitting these bushes to see where the front end knocking is coming from. I honestly give up the dam thing!
Morne told me that the right conlink? (Aka stabalizer bar) is worn and needs replacing. Other than that - he says everything else is fine/ no play etc.
I have bought a new conlink from GW this afternoon and will fit it tonight. However something tells me I will still have knocking sound up front.
The knock happens over every tiny little frikking bump in the road. And only SOMETIMES over speed bumps - but not always.
If there is still knocking upfront - what to look at next? The following has been checked/ replaced:
LCA Bushes (left and right replaced)
Conlinks - (Left and right replaced)
CVs - checked and no issues.
Wheel bearings - checked and no issues
Tie rods - checked and no issues.
Ball joints - checked and no issues.
Where next?
Just making this post now - as I know I will be making it later on after fitting the new conlink and finding out there is still knocking!!
By the way - thanks Morne - you're a start - bushes are all good - and you even reset the service indicator!
Where next?
2008 SEAT Leon Cupra - Banshee
Exes:
2006 Polo 9N3 - 1.6i
2003 Citi.com 1.3
2003 Opel Corsa Lite
- MeanTdi
- The Imposer Mod-whore-rator
- Car Make: Subaru
- Car Model: WRX
- Membership No: 1153
Re: Where to next?
Morne is spot on. I think it is the droplink. Attaches to the stabilizer bar.
To help you check - if you turn right over a bump if the right one is worn then it will make a noise. If you turn left over a bump if the left one is worn then that one will make a noise....
Marco
Current: Subaru WRX
Ex: VW Polo 1.9 TDI Sportline
Ex: VW Golf VR6
Ex: VW Golf 1.8 GTi 16v
Current: Subaru WRX
Ex: VW Golf VR6
- VWicked
- Car Model: Golf 2 GTi
- Membership No: 1492
Re: Where to next?
Hey dude, I had the same issue with my TDI a fokken knock sound. I eventually after replacing almost everything, found that it was the link rod. Its basically the short rod where one end goes to the strut and other to the stabiliser bar. It has two ball joints on either side. Take it off and feel if it has play. I have my old ones lying at home if you want to compare/test them.
1992 Golf Mk2 GTi VR6
1994 Caddy 1800 Sport
- VWicked
Re: Where to next?
I think we are talking about the same thingMeanTdi wrote:Morne is spot on. I think it is the droplink. Attaches to the stabilizer bar.
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
YessirVWicked wrote:I think we are talking about the same thingMeanTdi wrote:Morne is spot on. I think it is the droplink. Attaches to the stabilizer bar.
Edit to add:
Actually just did a search - Called a connecting rod, OE part no. 6Q0 411 315N
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Tander
- Car Make: Seat
Re: Where to next?
Did I just buy the wrong thing from GW then?
What I bought is a bar that has two right angle bolts on each end....
Exes:
2003 Citi.com 1.3
- Tander
- Car Make: Seat
Re: Where to next?
Then I am sure I just got the wrong thing. Do you have a pic maybe bud?MeanTdi wrote:YessirVWicked wrote:I think we are talking about the same thingMeanTdi wrote:Morne is spot on. I think it is the droplink. Attaches to the stabilizer bar.
Edit to add:
Exes:
2003 Citi.com 1.3
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
I think you bought the right thingTander wrote:Did I just buy the wrong thing from GW then?
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
Tander wrote:Then I am sure I just got the wrong thing. Do you have a pic maybe bud?
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- VWicked
Re: Where to next?
if you turn your wheel to the right and peep under the fender of your right wheel you will see a 40cm or so rod going fromyour shock to your stabiliser bar.
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
Another pic
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Tander
- Car Make: Seat
Re: Where to next?
Okay - Marco - that is exactly what I got. But at each end the bolts move - is this right?
VWicked - yip - just checked - I see it.
Exes:
2003 Citi.com 1.3
- VWicked
Re: Where to next?
MeanTdi and I posting at the same time,lol.
- AlexTDi
- Car Model: '15 Polo GTI
- Membership No: 1724
Re: Where to next?
i must be having the same problem and its only on my right side too,
i can only hear it when im driving really slow like in a driveway and there are small bumps. it makes like a cracking noise,
my car has been dropped and it was done about 2 years ago, but the noise only happened these past couple of months.
please let me know what the solution is...
Alex
VWCSA Member No. 1724
Race Car: Polo Vivo GT
Daily:
'15 6C Polo GTI DSG
'06 1.9 TDI Sportline
'06 BMW 320D M-Sport
Weekend Toy: '84 Golf MK 1 GT
Race Car: Golf MK1 2 Door
Daily:
'15 6C Polo GTI DSG
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
Hey 1.9TurboVw1.9TurboVw wrote:i must be having the same problem and its only on my right side too,
Yes, dropped cars do wear down these links slighlty quicker.
This is what I have heard to help you check - if you turn right over a bump if the right one is worn then it will make a noise. If you turn left over a bump if the left one is worn then that one will make a noise.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Tander
- Car Make: Seat
Re: Where to next?
The noise on my car is not cracking - it is like a soft knocking sound.1.9TurboVw wrote:i must be having the same problem and its only on my right side too,
My concern now is the part I got from GW - the two end bolts can move up and down and guy at GW said this was correct - I am not so sure.
Exes:
2003 Citi.com 1.3
- Tander
- Car Make: Seat
Re: Where to next?
Will try this on way home - but I have been listening to the noise a lot and cannot make out if it is right or left of car.MeanTdi wrote:Hey 1.9TurboVw1.9TurboVw wrote:i must be having the same problem and its only on my right side too,
I just hope GW have not sold me a faulty/ wrong part. It was in a sealed packet - but ja..eish.
Exes:
2003 Citi.com 1.3
- AlexTDi
Re: Where to next?
@Tander please let me know if that sorts out the issue, mine has been doing it for a few months so its getting worse and that probably why its sounding like snap crackle and pop lol
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- dazza
- Car Make: VW and VW
- Membership No: 1327
Re: Where to next?
Common issue on the 6n, 6l,9n and 9n3 suspension it seems.
My droplinks were replaced on the Ibiza at like 17000km or somthing stupid...obviously dud parts, but since then all has been well
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
Yes, like a 'gunk-gunk' sound.Tander wrote:The noise on my car is not cracking - it is like a soft knocking sound.
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Tander
- Car Make: Seat
Re: Where to next?
Exactly - and come to think of what 1.9TurboVw just said - it has gotten a lot worse over the last few months!MeanTdi wrote:Yes, like a 'gunk-gunk' sound.Tander wrote:The noise on my car is not cracking - it is like a soft knocking sound.
But are the bolts meant to be able to move up and down like this new part does?
@1.9TurboVw - Unless the new part is faulty (Waiting for answer on this if anyone knows the above?) I am fitting it tonight and will post results tonight as well.
I just hope it resolves the problem as it is driving me nuts to the point I am starting to hate driving the car...this is not good!
Exes:
2003 Citi.com 1.3
- MeanTdi
- Car Make: Subaru
- Car Model: WRX
Re: Where to next?
I have never fitted it so have no idea. I guess they must move up and down as the camber changes.Tander wrote:But are the bolts meant to be able to move up and down like this new part does?
Marco
Current: Subaru WRX
Ex: VW Golf VR6
Current: Subaru WRX
Ex: VW Golf VR6
- Tander
- Car Make: Seat
Re: Where to next?
This is what the oke at GW said - "Your shocks etc move - so those parts have to as well"MeanTdi wrote:I have never fitted it so have no idea. I guess they must move up and down as the camber changes.Tander wrote:But are the bolts meant to be able to move up and down like this new part does?
So I guess it is fine then.
Thanks for all the help guys.
Hoping it is not a pain in the ass to fit..
Exes:
2003 Citi.com 1.3
- AlexTDi
Re: Where to next?
cool thanks might be the solution to my problem too, how much did GW charge for it?
Alex
Daily:
'15 6C Polo GTI DSG
Daily:
'15 6C Polo GTI DSG
- Tander
- Car Make: Seat
Re: Where to next?
They are R170 each. I only got one due to replacing the left hand one a few months ago at kwik fit. (Should have gotten them to do right side as well, but oh well)1.9TurboVw wrote:cool thanks might be the solution to my problem too, how much did GW charge for it?
Exes:
2003 Citi.com 1.3
