Hi Hi
I have a mk1 2l carburator conversion.
I want to change to Fuel injection....Please advise where I can obtain the parts and what the cost will be?
Which mp9 map for 2l 8v?
- phillip
- Car Make: Ford
- Car Model: 225 ST
- zain_c
Re: Which mp9 map for 2l 8v?
never f*cking worksTinTin wrote:search function!
2010 Honda Accord K24
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
04 Citi 14.7 s2s Killarney
06 MK5 Golf
92 MK2 2.0 16v GTi Exec
96 MK3 GTS
1992 MK2 Jetta CSi
ex:
86 MK2 Jetta CLX
88 MK2 Golf CSL
14 6R Polo
97 Caddy
83 MK1 GTi
06 MK5 Golf
96 MK3 GTS
you never fu*cking workzainyboymk1 wrote:never f*cking worksTinTin wrote:search function!
- Registered for: 3 years 11 months
Re: power loss on 2l 8v
Hey guys hope you are all well, I hope theres someone on this forum that has had and solved the following problem I'm experiencing
I recently fitted a 272cam to my 2l 8v caddy(running polocup and uni chip)
Herman from zwillinge performance tuned it and all was fine up until I heard a slight ping at 7000rpm
I went back for a check up but then we started having issues, starting pinging in all gears and ****
Tried replacing the knock sensor and it seemed to rid us of the pinging but then caddy lost all power from about 100kw to 62kw when it reached optimum temp
Herman went as far as doing a check on the harness, ecu and chip seemed fine but bakkie was still like earthing if I can put it that way, put in a new earth, cleared the map sensor etc etc, then she ran normal and then again boom low power.
Plugged it in and got a few errors 2 that kept coming back was the knock sensor and adaption limit not reached, intermittent
So Herman is gobsmacked and referred me to Allan
So please if anyone has encountered this and can advise I'd appreciate it
Thx
Thx
I agree with Tin Tin
- Car Model: Caddy
Still never works.Sabris wrote:I agree with Tin Tin
Sent from my SM-N770F using Tapatalk
