Hey guys. While doing my research I came across Haltechs website, they give every single sensor's pinout.
Thought I'd share it with the club, hopefully it helps.
https://support.haltech.com/portal/en/k ... -turbo-20v
Wiring Diagram for 1.8 20VT
- Car Model: '84 Mk1 2.0 20v ITB's
- Membership No: 3004
Re: Wiring Diagram for 1.8 20VT
Sometimes its all these things and the support you have access to, that warrants choosing a management system, compare to the cheaper ones where you will be stuck figuring out stuff from A to B. (Keep that in mind for you build)
- ChrisMaxx
Exactly. That's where a basic aftermarket ECU wont just cut it. The support is absolutely astonishingQuik-Trix wrote:Sometimes its all these things and the support you have access to, that warrants choosing a management system, compare to the cheaper ones where you will be stuck figuring out stuff from A to B. (Keep that in mind for you build)
