Good day
I hope I'm writing this thread on the correct space...
Please assist I'm driving a vw polo gti 1.8T 2007 model. The car was fixed recently after it snapped a timming belt. After everything was done the car starts and idle perfectly but if you drive it for longer distance it just cuts and the motor stops with the instrument cluster still on not showing and warning lights.. After a minute or two it starts normally and drives for couple of killos and the process repeats over and over... And you can smell petrol from the inside as well as outside... I took it to be scanned and it shows no faults....
Please assist
Sent from my JNY-LX1 using Tapatalk
Vw polo git 1.8 t cuts off and won't start
- Car Make: Vw, Bmw, Merc
- Car Model: 81 Vw Mk1 Cabrio,15 Mk7GTi
- Membership No: 3258
Re: Vw polo git 1.8 t cuts off and won't start
My Polo Gti 9n3 Uses to cut and stutter when hot ,Also Hot /Warm starting was an issue .Turns out it was the crank sensor in the front of the engine block. Its magnetic so it stopped working once it got warm . Simple fix just need small hands to get between the radiator and engine block . I also didn't get any warming lights ,just lack of power and rough idle. So check that out .
Part was +-R600 at Goldwagen
Also check your ground cable from the body to the battery. These models love to break that cable at the body ground point . Make sure it hasnt already torn the lug
Thanks guys it turned out to be a crank sensor all is well...
lol Figured, Glad its sorted . I struggled before we figured it was the sensor
