1.2 TSi CJZ engine timing marks
JayMechs
Post by JayMechs »
Hi All
Please help, I tried to look for the timing marks on the cam pulleys but could find any. Does the two have any reference to indicate TDC?
missioner
Car Model: '87 MK1 Golf Citi
Re: 1.2 TSi CJZ engine timing marks
Post by missioner »
You need a engine timing kit.
Interference cam and crank pulleys mean that you will not find any marks anywhere. The crank is pinned and the cams are locked using the tool set, the cam belt is installed with all the pulleys loosened off and able to rotate easily. The belt then get tensioned to spec and all the pulleys are tightened in sequence. Lock tools are removed and engine rotated 720°. Reinstall the tools to confirm timing, if it all fits easily then close it up and hit send.
Sent from my M2101K6G using Tapatalk
JayMechs
Post by JayMechs »
Thank you so much, I'm practically screwed without proper tools.
missioner
Post by missioner »
JayMechs wrote:Thank you so much, I'm practically screwed without proper tools.
Garage tool supplies.
https://store.gtsupplies.co.za/products/vw-timing-tools
Hit this site for a start. They should be able to help you fairly quick.
JayMechs
Post by JayMechs »
Hi Missioner
I came alright. Apologies for late reply.
Many thanks.
