Help?? Golf 5 gti cooling fans staying on
Twkgti
Registered for: 4 years 4 months
Post by Twkgti »
Hi guys, need some help with my golf 5 gti. As soon as a start my car(even when cold) the fans come on, when I switch the car off they stay on until the battery goes flat. I have searched for a fan relay but cannot find it.. Anyone had the same issues.. Please help. Thanks
JCTPUBLISHERS
Registered for: 3 years 9 months
Re: Help?? Golf 5 gti cooling fans staying on
Post by JCTPUBLISHERS »
I think those relay are build into the fan? Have you scan for fault codes?
JCTPUBLISHERS
If you looking for parts for your GTI i can recommend someone?
Twkgti
Post by Twkgti »
Hi... Yes I have scanned the car... No codes came up
Car Make: VW, Mini, Slowyota
Membership No: 3337
Post by kingr »
your car has x2 fans. the big one has the fan control module and relay circuit built into it, this can fail or the fan brushes can get stuck.
do both fans come on?
can you use vagcom to switch on the fans? you should be able to do this with the ignition on.
Kurt #3337
- 10" Mx5 NC2 (main daily)
Twkgti
Post by Twkgti »
Yes both fans come on
dcmk4
Registered for: 10 years
Car Model: MK7 GTi
Post by dcmk4 »
There are two coolant temperature sensors. One above the transmission next to the side of the head and another below the intake manifold. Make sure both are connected. Those could trigger the fans to run if unplugged or broken.
'14 Golf Mk7 GTI
THANAS STG/// ECU&DSG
Littco L380x
All the ponies
Twkgti
Post by Twkgti »
Cool... Will have a look
