7 speed Dsg DQ200 BASIC SETTINGS
kingozzi
Registered for: 6 years 8 months
Car Model: PGTI1.4tsi 172kw 309nm(crank)
Post by kingozzi »
Good day fellas. I have a problem that Google can't help me with, I'm working on a 1.4 tsi jetta with dsg DQ200 box! Done a clutch replacement and now when doing basic settings on the 1st stage (engine on not running) it shows 255 101 0, It should be showing 4 0 0 meaning I can move on to stage 2 (engin running) the mechatronics wasn't touched the breath was blocked no oil leakd out or anything like that..
Baldwin02002
Car Model: Mk2 GTS
Re: 7 speed Dsg DQ200 BASIC SETTINGS
Post by Baldwin02002 »
Try this http://wiki.ross-tech.com/wiki/index.ph ... ic_Setting
Otherwise start the car and let it idle for few minutes to warm up an oil. Hold a brake pedal and change gears for couple of times from Park - Drive - Neutral - Reverse.
Below are the procedures for 6 speed DSG and dont think will work:
Clutch Adaptation
Control Module Software Version < 0800:
Group 062
[Go!]
Activate the Basic Setting.
[ON/OFF/Next]
Special notes.
When found in the early software level (0627/0628) (8N) Audi TT:
Basic Settings group 062 may take several minutes to complete. The final values may report: [18 | 18 | .285 | .24] and Basic Settings will report ON when finished.
If Basic Settings group 062 reports ERROR:| Group 062| Not | Available try test driving the vehicle and repeating at normal operating temp.
Internal Ref: ST?ID=66725 and E?ID=309867
Control Module Software Version >= 0800 :
Group 067
[Go!]
[ON/OFF/Next]
Reset Values (Clutch Safety Function)
Group 068
[Go!]
[ON/OFF/Next]
Reset Values (Pressure Adaptation)
Group 065
[Go!]
[ON/OFF/Next]
Reset Values (Steering Wheel Paddle Installation)
Group 063
[Go!]
[ON/OFF/Next]
S4 2004 --> Stock
A3 2010 1.8T Cabrio --> Stock
Previous
Golf Citi 2.0 8v MP9 2007
Jetta 4 V5 10V
Honda CB400 '74
