2.0tfsi vacuum pump cover plate seal leaking
- kingr
- Car Make: VW, Mini, Slowyota
- Car Model: Mk1 2 Door, Hilux D/C
- Membership No: 3337
Hello,
Does anyone have advice regarding where I can source the vacuum cover plate seal/o-ring locally?
This is the cover and the red circle indicates where my cover is leaking oil.
VW & GW doesn’t sell this seal as a single part and only sell the entire vacuum unit. The vac unit from VW is R9k and R2.3k from GW.
I have found a company in the US called RkxTech that sell the seal kit alone for $29 https://www.rkxtech.com/products/rkx-au ... 4-q5-a5-a6
There site also indicates that this same seal is used on the 1.8t.
I don’t want to replace a working vac pump because of a busted seal, any advice to source this part appreciated.
Here’s the aftermath of this leak.
Kurt #3337
- 10" Mx5 NC2 (main daily)
- 80" VW Mk1 2 Door Golf 8vt project 192wkw/314nm
- Car Model: Mk5 gti
Re: 2.0tfsi vacuum pump cover plate seal leaking
Howsit buddy my s3 8p had the same problem the pump is exactly the same as urs . I sent it to yosh. At Darkartz performance he supplied and fitted the kit for me. Email him and ask him for a kit
Just to confirm it's for ur mk5 gti right?
viewtopic.php?f=11&t=217296
Previous :too many to list
- kingr
Yes, it’s for my mk5 bwa.Trishen94 wrote:Howsit buddy my s3 8p had the same problem the pump is exactly the same as urs . I sent it to yosh. At Darkartz performance he supplied and fitted the kit for me. Email him and ask him for a kit
Tx bud, I will mail him. The car is anyway due for the vvt timing chain replacement with him maybe this can be fixed then.
Hopefully I can source the part before taking the car to him & diy it. I don’t want the leak to continue if it’s a simple fix.
Kurt #3337
No problem buddy. If I look at it it doesn't seem very difficult to diy it but maybe just double check. U know sometimes things look easy but when u half way into it, u think man was I wrong I shouldn't haven't started this happened to me many timeskingr wrote: ↑Mon Jun 28, 2021 7:25 pmYes, it’s for my mk5 bwa.Trishen94 wrote:Howsit buddy my s3 8p had the same problem the pump is exactly the same as urs . I sent it to yosh. At Darkartz performance he supplied and fitted the kit for me. Email him and ask him for a kit
But good luck let me know how it goes and if u do diy it let me know how difficult it is so if I do have the issue again I know what to do
- kingr
I find stripping parts is always easy, put stuff back is always hardTrishen94 wrote: ↑Mon Jun 28, 2021 9:24 pmNo problem buddy. If I look at it it doesn't seem very difficult to diy it but maybe just double check. U know sometimes things look easy but when u half way into it, u think man was I wrong I shouldn't haven't started this happened to me many timeskingr wrote: ↑Mon Jun 28, 2021 7:25 pmYes, it’s for my mk5 bwa.Trishen94 wrote:Howsit buddy my s3 8p had the same problem the pump is exactly the same as urs . I sent it to yosh. At Darkartz performance he supplied and fitted the kit for me. Email him and ask him for a kit
I mailed Yosh, will this thread updated.
Kurt #3337
- kingr
Yosh doesn't sell a repair kit.
GW Delary quoted me R2050 for the complete vacuum unit with club member discount, I'm ordering a unit from them today. I will update with pics once installed.
Kurt #3337
My one was just the o ring that was perished?
- kingr
ok, I have the same issue.
How did you end up fixing yours?
Kurt #3337
I took it apart and notice one of the o ring was perished. Took sample of o ring to the spare shop.
- kingr
I had the same idea, I guess could try my local hydraulic shop. I'm in Kimberley, my options with a variety of spares are limited here.JCTPUBLISHERS wrote: ↑Tue Jun 29, 2021 11:24 am I took it apart and notice one of the o ring was perished. Took sample of o ring to the spare shop.
Kurt #3337
try sealing solutions they in kimberly
- kingr
wow thanks for this tip!
I will remove the o-ring tonight and take it to them tomorrow.
Kurt #3337
That's strange. If I remember correctly he did repair mine. Il look for my old invoice later this afternoon and see if he repaired or replaced it. Maybe I am being mistaken
- kingr
I just removed the seal/o-ring. It’s brittle and busted. This is definitely my leak. I will try the rest of the week to source this seal before committing to a vacuum pump.
What makes this a non-standard shape is this little hump.
Kurt #3337
- kingr
JCTPUBLISHERS wrote:My one was just the o ring that was perished?
Did you replace the same seal and did you replace it a normal circle seal?
Kurt #3337
Hi. Just my 2c comment I think u can put in a normal o-ring but make sure the thickness and diameter is the same or just a little thicker than the oem 1 and it should take the shape on that little flat spot without an issue. But lets see if any1 else comments otherwise
- kingr
I couldn’t resist a diy attempt and sealed it up with LiquiMoly Sealant. I basically put smeared sealant into the groove where the oem seal must seat. I will let this stand overnight and test it tomorrow.
Inside seal wall cleaned with paper towel.
Diy gasket
I then torqued the bolts 10nm in a start pattern. This is just a try, I have nothing to loose.
Diy gasket
Kurt #3337
Just a normal o ring.
i recall purchasing this seal/o-ring from VW and yosh fitted this for me when mine was leaking.
i will check if i can find the part number and post here.
2012 VW Golf 6R DSG
2011 BMW E90 320d M Sport Auto
2009 VW Golf 5 GTI DSG
2014 VW Golf 7 Gti
2010 Honda Civic Type R - Championship Edition
2011 VW Golf 6 GTI DSG
2003 RunX RSi(RIP) :weep:
1998 Civic VTEC
2012 VW Golf 6R DSG
2014 VW Golf 7 Gti
1998 Civic VTEC
- kingr
I will appreciate a part no.2SCOOPS wrote:i recall purchasing this seal/o-ring from VW and yosh fitted this for me when mine was leaking.
So far it’s not leaking with temps reaching 95 degrees Celsius.
I found it hard to believe that Yosh didn’t have a answer to replace the seal.
Kurt #3337
link to the part number on ECS tuning:kingr wrote: ↑Wed Jun 30, 2021 8:54 amI will appreciate a part no.2SCOOPS wrote:i recall purchasing this seal/o-ring from VW and yosh fitted this for me when mine was leaking.
https://www.ecstuning.com/b-genuine-vol ... 06d145117/
i did some research when mine was leaking and found that this o-ring/seal is the culprit.
found the part number( as above) and bought it from VW and had Yosh change it when he was doing some other maintenance work on my car.
the o -ring i purchased was perfectly round though no hump etc. as can be seen on ECS website as well.
2012 VW Golf 6R DSG
2014 VW Golf 7 Gti
1998 Civic VTEC
2012 VW Golf 6R DSG
2014 VW Golf 7 Gti
1998 Civic VTEC
- kingr
Tx bud.2SCOOPS wrote:link to the part number on ECS tuning:kingr wrote: ↑Wed Jun 30, 2021 8:54 amI will appreciate a part no.2SCOOPS wrote:i recall purchasing this seal/o-ring from VW and yosh fitted this for me when mine was leaking.
My cousin who is a VW Mech advised that vw upgraded the vac pump on later models. Maybe you had the upgraded pump with round seal. I cant see how that seal will work on my car. He also said the dont sell the seal with the hump.
So far no oil leak after reaching 120c with some spirited driving.
I will keep my eyes on this over the next couple of weeks & if no oil leaks I’m going to mark this as “fixed”. If it leaks, then I buy the GW pump.
Kurt #3337
