Hi guys, had an independent mechanic come round when I was out of the country to replace water pump highly recommended by a friend (some recommendation this turned out to be)
Long story short he removed the water pump broke loads of wires in the process,
I'm thinking his taken a few things as well on inspection of the fuse box it seems some fuses might be missing but I can't confirm.
Can anyone share a picture of their fusebox in the engine bay tried Google but not having much luck.
Many thanks
Polo GTI 6C Engine Bay Fusebox
- Car Model: Polo GTi 6C
- Zie_Khumz
- Registered for: 9 years 5 months
Re: Polo GTI 6C Engine Bay Fusebox
Have you tried using the owners manual?Catalz wrote:Hi guys, had an independent mechanic come round when I was out of the country to replace water pump highly recommended by a friend (some recommendation this turned out to be)
Many thanks
Sent from my SM-A715F using Tapatalk
- Membership No: 2033
Also, not all the fuse bays are populated (in the various modules / spec levels)
Post up your fusebox pic as well.
ps: edit, is you car up and running now?
HOWIE-WP,
Tow Car:1996 VW Golf GTi
RoadCar:2008 VW Golf5 .:R32
Hi guys yes the car is up and running but I haven't taken it on a long journey yet just want to make sure everything is back in place as should be.
I appreciate not all fuse boxes are in use.
Regarding the owners manual I did look for it but as I'm hardly here I've no idea where it's been placed
Greatly appreciate any help you guys can give on this thanks
- Car Make: SEAT
- Membership No: 478
Fuse assignments
Sent from my SM-G955F using Tapatalk
'20 SEAT Tarraco XC 1.5 TSi
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'04 Golf MKIV GTi.:R
'99 Citi Golf 2.0i
'12 VW Up! 1.0 MPi
'06 Golf MKV GTi
'99 Citi Golf 2.0i
Thank you so much Macman really appreciate it. Happy New year
