Hello vdub Fam. I was doing head work on my polo 6R GTI(1.4).
Turns out I also need new pistons. The car is not running crazy power, just 168kw on the flywheel..now I dont want forged coz I'm not planning on making more power.. now I dont want OEM also coz they are prone to failure.
Question.
Which aftermarket pistons are good enough?
NB no forged pistons please
Thanks yall
Pistons advice PGTI 1.4 tsi
- Car Model: PGTI1.4tsi 172kw 309nm(crank)
Re: Pistons advice PGTI 1.4 tsi
Most aftermarket pistons that are decent to high quality will most likely be forged for that motor.
- ICE King
Semi Forge Mahle pistons will do the trick - actually OEM pistons.
Your OEM pistons wasn't prone to failure , detonation caused it to fail as those are high compression motors + SA pump fuel = kaboom.
I would go lower compression pistons and add more boost instead
- Killerwatt
- Car Make: AUDI
- Car Model: S3
The twincharged motors are fairly stressed out the box. Even stock motors have reported issues with the ring lands cracking.
Any reason for not going forged? That's probably the only way to solve the issue completely.
- Preggz
- Car Model: 06 Velociti & 13 6r PGti
I'm sitting with the same situation and my warranty don't cover detonation. And my car is bone stock
"I would go lower compression pistons and add more boost instead"
How would one go about this route
LöW Ridër Velociti
JOMs FTW
Reflex Sliver Polo 6R GTI
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
Actually the 1.4 twinchagre engines brake pistons all over the world. I done ma fair share of researchICE King wrote: ↑Fri Dec 11, 2020 8:40 am Semi Forge Mahle pistons will do the trick - actually OEM pistons.
Well coz ama be tempted to forge the whole motor .. but seeing vw prices on pistons I might as well go forge.. any idea where I can get them here in SA? Google is showing me UK or USA with a s@# ton of shipping feeKillerwatt wrote: ↑Fri Dec 11, 2020 10:18 am The twincharged motors are fairly stressed out the box. Even stock motors have reported issues with the ring lands cracking.
- Preggz
[/quote]
Howzit
I have contacted the guy below his a agent of Wossner / PEC Forged Pistons & Rods
he Quotes on Bore size unfortunately I don't know the bore size.
please ley me know if you come right and the Price. I'm looking to go same route.
ksmotorsport.co.za
Karl Stegmann – Owner
Call/sms: 082 966 2548
Call/sms/whatsapp: 083 553 1295
E-mail: info@ksmotorsport.co.za
[/quote]
Howzit
ksmotorsport.co.za
LöW Ridër Velociti
JOMs FTW
HnR Springs
Dp
Forge Intake
SW (Dark Arts)
- ICE King
You correct , one of the users ,that owned a twin charge engine, on the forum looked into this issue , they checked the car for mechanical faults and proceeded to log the car while on stock map, logs revealed that the motor was running lean , car was remapped and AFR's improved ,kingozzi wrote: ↑Fri Dec 11, 2020 3:32 pmActually the 1.4 twinchagre engines brake pistons all over the world. I done ma fair share of researchICE King wrote: ↑Fri Dec 11, 2020 8:40 am Semi Forge Mahle pistons will do the trick - actually OEM pistons.
