DQ200 DSG 7 speed dry dsg box.
Jitesh
Registered for: 6 years 3 months
Post by Jitesh »
Hi. I recently just purchased a 2013 golf 7 tsi dsg comfort line has 126000km on the clock. Can anyone advise me on how to maintain my dsg gearbox as these are known to give issues as I’ve been told. Main issue being the mechatronics. If there is a way to avoid these issues please let me know or is it a ticking time bomb.
deon rupnarain
Re: DQ200 DSG 7 speed dry dsg box.
Post by deon rupnarain »
Jitesh wrote:Hi. I recently just purchased a 2013 golf 7 tsi dsg comfort line has 126000km on the clock. Can anyone advise me on how to maintain my dsg gearbox as these are known to give issues as I’ve been told. Main issue being the mechatronics. If there is a way to avoid these issues please let me know or is it a ticking time bomb.
Hey buddy ,
Great cars those tsi golfs are.
Hope you enjoy it.
Wrt to your query, I'd wont worry too much if you bought the car with FSH , SPARE KEYS and most importantly a warranty etc etc and from an owner whom took care of it because if the records show , your dsg gearbox should of been serviced properly by the agents ....
If not ,
Cross your fingers and enjoy it...lol.
Sorry If I didn't help at all.
Cheers
Sent from my SM-G960F using Tapatalk
Current :
2008 1.9tdi 6 speed 4door :grin:
2022 Toyota Corolla Xr :bang:
Jitesh
Post by Jitesh »
It does have FSH from VW but I’m yet to request the records to see what has been done and maintained up to now. Also I did enquire from a dsg specialist at Vagbox and they recommended a gearbox service at 150k Kms.
Callum229
Post by Callum229 »
Do a DSG service regardless for peace of mind, check clutches on how much is worn to get an idea on how it was treated.
The DSG gearboxes are reliable if looked after, with the dry clutch you want to refrain from rolling the car and when stopped, refrain from inching forward or creeping forward and just stop until you can move off smoothly and shift into second. The most common problem with them is people inching forward or revving the car and the car ends up riding the clutch, wearing it down fast and warping the pressure plate.
Jitesh
Post by Jitesh »
Thanks for the advice. What I’ve done is put the e brake on auto hold so I avoid rolling forward or back once I can take off I basically just drive instead of like riding the clutch.
Callum229
Post by Callum229 »
That is the right way, forgot that the Golfs have auto hold, the Polos are the ones suffering though with the manual handbrake. Wish you many more trouble free miles!
Jitesh
Post by Jitesh »
Thanks bud.
Kavi4GP
Car Make: Toyota
Car Model: Corolla D4-D
Membership No: 2016
Post by Kavi4GP »
Callum229 wrote:Do a DSG service regardless for peace of mind, check clutches on how much is worn to get an idea on how it was treated.
DQ200 doesn't have a service interval , it's normal manual gearbox oil in the transmission part and hydraulic in the mechatronic portion, these either leak or the clutch packs fail at random.
2013 A3 1.6 TDi S-Tronic 8V.1
2013 Ford Focus 2.0 Sport
2011 Hyundai i20 1.4
2006 Toyota RunX
Callum229
Post by Callum229 »
High mileage DSG boxes should always be serviced, oil degrades and separates and contaminates from the transmission like wear and tear will also be present.
No service interval or lifetime fluid for transmission always screws the consumer as it just prevents you from servicing the transmission and it just lasts about until the warranty is expired, then you screwed.
That is why, if you get a DSG, always service it for peace of mind. That way you less likely to get a mechatronic failure or solenoid failure and you taking out the contaminates in the oil especially if the car was driven hard or not looked after.
Trishen94
Car Model: Mk5 gti
Post by Trishen94 »
Callum229 wrote: Thu Dec 03, 2020 1:49 pm Do a DSG service regardless for peace of mind, check clutches on how much is worn to get an idea on how it was treated.
Sorry for the hijack... I've also just recently purchased a polo gti also dq200... Tell me how do u check the wear on the clutch?
viewtopic.php?f=11&t=217296
Previous :too many to list
Jitesh
Post by Jitesh »
If you based in Pretoria you can contact Vagbox I’m sure they can assist.
Callum229
Post by Callum229 »
You will need VCDS.
https://www.r8talk.com/threads/how-to-c ... vcds.7408/
Hopefully it works on your car though.
Trishen94
Car Model: Mk5 gti
Post by Trishen94 »
Callum229 wrote: Tue Dec 08, 2020 12:56 pm You will need VCDS.
Thanks buddy will try out this afternoon and let u guys know
Trishen94
Car Model: Mk5 gti
Post by Trishen94 »
Trishen94 wrote: Wed Dec 09, 2020 1:23 pm
Don't work... On my vcds and my car
