gotech managemnt blows pick up at distributor
Solomon34$
Post by Solomon34$ »
hi guys names gregory. am a vw fan. so u guys mite get upset but am hoping. irl still get help. i bought honda vtec turbo. big mistake. lots of problems but 1 of them has lead to making a mistake at the distributor i switched the power wire into the earth an it blew the hall sensor on the distributor . i have a convert distributor with just 3 wires power earth an signal. discovered the hall sensor blew had it repaired at local distributor centre. got it back had a managment guy come to make sure all good. gave the car a crank no spark no signal to gotech managment . so we checked the power supply read 10.5volts battery was a bit low from the swinging he said still ok to get a start. signal wire to gotech 5volts an earth..had the relay changed . theres 2 wires inside the grey casing to test gotech for signal to box. red an blue it gave a signal back. am.lost not entirely but think mite change the unit to gotech but hoping to save that money.please help
