Hi Guys
I want to fit a dicktator unit in a Audi S3 1.8T AMK engine. The engine has 4 pin coils, will the dicktator be able to fire the coils ?
I have read that these coils fire with a positive signal and dicktator sends a negative pulse for ignition via the modules. Is there a way to use the 4 pin coils without changing to the 3 pin coils.
Also should I use MAP or TPS ?
Thank you
Audi S3 1.8 T Dicktator
- chucker02
- Car Model: Citi ADY
Re: Audi S3 1.8 T Dicktator
Why would you want to do this?
1971 VW beetle
1971 VW beetle
Agreedchucker02 wrote:Why would you want to do this?
CANBus electronics porked like a girl in a bondage movie. Its not pretty afterwards.
Flash the stock ECU with REVO and be done.
Diktator would be like using a P4 with onboarding graphics from 2004 to try play Crysis in comparison to the much more sophisticated OEM system.
- chucker02
missioner wrote: ↑Fri Oct 18, 2019 9:57 pmAgreedchucker02 wrote:Why would you want to do this?
1971 VW beetle
1971 VW beetle
