Good Morning.
I have a golf 7 1.4TSI. the car used a lot of oil so VW did an oil consumption test and it failed. as i have an extended warranty with hollard i took the car to an RMI approved workshop. they stripped the engine and found the 3rd and 4th pistons are fried and the block id worn out. we cannot find a second hand block as they are worn out also.
please could someone help us with a repair for my car.
Golf 7 1.4?TSI Block Problems
- PoloB
- Car Model: POLO 6S
Re: Golf 7 1.4?TSI Block Problems
Where are you based? And are you looking at repairing privately or through your extended warranty?
Vw Polo 6 Sedan
Quantum Tunning Software
Eibach Springs
Smoked Tail lights
17 Inch A-Line Spree wheels
Eibach Springs
Smoked Tail lights
- Registered for: 4 years 9 months
Hi
I am based in Alberton. the car is currently at the RMI workshop. At this moment i just need the car, so i dont mind how i can repair it.
Does the extended warranty cover the engine damage?
If yes, they must pay up and get you a new block/engine. Not second hand, new.
The Extended Warranty only covers engine damage up to R20000. Brand New Engine +-R120000.
- Car Model: MK7 GTI
Hope you come right buddy, was in the same boat but offloaded mine (trade in)
Sent from my SM-N960F using Tapatalk
MK7 GTI
Revo Tuned
Revo Intake
Roque Performance DP
Revo Tuned
Revo Intake
bore and put in oversize pistons?
Bad idea bro these new engines are weak for suchpanic-mechanic wrote:bore and put in oversize pistons?
Sent from my BLA-L29 using Tapatalk
How it played out on mine with same problem and to rebuild engine was going to cost alot and apparently it wasn't a long term solution as per vw mechanics. We got an import engine came after one week fitted in and car been fine ever since. Costs 35k for while job so maybe take 20k and add 15 maybe would be cheaper on your end import engines are around 20 to 25k and labor is the issueyusheem wrote:The Extended Warranty only covers engine damage up to R20000. Brand New Engine +-R120000.
