Howsit gents,
anyone know where i can get a smoke test done to check for any vacuum leaks on my car?
car is throwing a P0101 constantly, changed pcv ,dv ,maf, checked maf wiring...
revs at idle sometimes move from 800rpm to 970rpm with a slud thud noise coming out of the exhaust
need help please
Smoke Test for a G6 - p0101 HELP!!!
- Car Make: VW, OPEL
- Car Model: MK6 GTI, LITE SPORT
- Colonel
- Car Model: Golf VI R
- Membership No: 2023
Re: Smoke Test for a G6 - p0101 HELP!!!
Check the o ring on your dipstick and the PCV constantina fittings (if they haven't been replaced)
Ive checked the o ring on the dipstick..seems to be fine, when i take off the dipstick when the car is idling, the idle is very ruff, have also checked pcv pipes and fittings.
- Colonel
Charcoal canister delete? Any reputable tuner should be able to assist with a smoke test. Try soapy water as well. Those O-rings on the intercooler pipes are kak as well
what role would the charcoal canister play in this? also how would i know if its gone bad?
the soapy water technique...it should be sprayed around intake manifold, vacuum lines and lower boost pipes? noticing a drop in idle?
Just Confirming...
thanks for ur advice!
Just Confirming...
- Colonel
Spray the soapy water on all piping joins and vacuum lines. It should foam/bubble where there is a leak. The charcoal canister throws an EVAP error code iirc, but it also might be linked if the pipe has gone brittle and broken off (happened on a friends car)Subbiah06 wrote: ↑Tue Jun 11, 2019 10:57 am what role would the charcoal canister play in this? also how would i know if its gone bad?
Just Confirming...
thanks will try that today and report back!
