Mk5 gti stalls out at high speed
- Registered for: 5 years
Hi guys,been having issues with my second hand mk5 gti,for some reason the car will stall out at high revs,car is stock.However it dont happen all the time,not sure if fuel cuts etc....recently did the cam follower,which was damaged,did the fuel filter aswel,which of i remeber was a 6.4bar.Please help guys,Any one around Durban can do a scan on vag for me please
- Car Model: MK5 gti
Re: Mk5 gti stalls out at high speed
Check the intake cam lobe that runs the hpf
'06 MK5 Gti - viezu sw and viper dp
'87 Jetta cli 16v exec
'08 polo 1.6 comfortline
'03 mk4 gti - revo sw and fastcar exhaust
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Going to take out the cam chain cover to check the lobe will post pictures to get the best feedback
- Ageless_ZA
- Storm Trooper
- Registered for: 12 years
- Car Make: SEAT
- Car Model: LEON CUPRA
- Membership No: 1906
You can check the lobe by removing the HPFP.
2008 SEAT Leon Cupra Stage 2
2008 Tiguan 2.0TDi 4Motion (Stage 1/Daily)
Exes:
2008 SEAT Leon FR Stage 3 (Hybrid K04)
2004 Stage 2 MK4 GTi
2007 Stage 2 MK5 Jetta Sportline
2008 Stage 3 SEAT Ibiza Cupra 20vT
2008 BMW 520D M-Sport
2008 Stage 2+ REVO SEAT Leon Cupra
2008 Stage 3 MK5 GTi
2006 Stage 1 Audi B6 1.8T
2001 Stage 1 MK4 TDi
1984 16v MK2 Throttled
1991 Audi 90 Cabriolet
It's HPFP sensor, its probbaly cracked and this happens when it hot.
replace HPFP and the problem will be gone
- Car Model: White-G5 GTi
yip,..was gonna say the same
i have hpfp if you want.
R2000
R2000
'85 mk2 gti 1.8 8v
'85 mk2 gti 1.8 8v
Hi guys,managed to open the cam chain cover to view the lobe,it has some wear on it,any ideas were i can get a second opinion on it in Durban,if the lobe is fine then showly i will need a new pump
why do you need a new pump?
Did you check the sensor on the pump for cracks?
Lastly unplug MAP Sensor and see if the problem persist...could be that too
The pump has some wear on it,has i have cam follower damage.However the sensors on the pump dont seem to have any cracks,theres 2 sensors 1 on the top and 1 on the left.The car as been running maf less
did the pumps go through the Cam Follower?
Maybe the Mafless tune is your problem!...anyway as said check the MAP Sensor on the throttle pipe
Hi guys,Been really busy,so i finally got around to change the Pcv and Plugs,However no fix to the problem.At high speed the engine stalls not sure what else to do,can any 1 recommend a good mechanic in Durban to assist me
- Car Model: Mk5 gti
Do u have acces to vcds ? If not get urself 1 then log the car and see whats the problem. im also 100% sure that if u check fault codes it would have definitely threw an error dont waste money buying pumps ,coils and plugs when it might be something on the opposite end of the world thats broken ...and if i may ask y do a mafless tune on a mk5 gti with ko3 turbo ? Or are u running big turbo setup
Log:
Engine speed
rail pressure actual and specified
Fuel pump pressure actual and specified (intank pump)
Cylinder misfire 1,2,3,4
Timming retardation cylinders 1,2,3,4
Boost pressure actual and specified
And ur lamda ...post the logs and some1 will assist
Original vcds is R7000 1st tool u should buy before even purchasing a spanner.... and pirate is R800 but also does the job
Log:
Engine speed
viewtopic.php?f=11&t=217296
Previous :too many to list
Hi Guys,Strange thing today so i took the car for a drive and removed the Maf sensor and the car was driving like a beast,however i still had a idle hunt.....no im confused.
R u running a cold air intake?
I think ur car DOES NOT have a mafless file coz if it was a mafless tune then whether its plugged in or not should not make a difference coz the maf DOES NOT work on a mafless tune
Hi was running the car wothout the maf,now that i put the maf back it works well, but then i dont get full throttle.Once removed then o get full response but huntting idle
- Wheel Whore
- Car Model: MK5 GTI
Those mafs are finnicky things. Any oil residue or debris build up and your readings go haywire. Get some electronic switch cleaner and clean that maf sensor properly. Don't be stingy with it. Make sure though that you don't use q20 or any other liquid. The switch cleaner is mostly alcohol and evaporates immediately, resulting in no remaining residue.
2008 Black Magic Golf 5 GTI - 194kw 414nm @ R&S Motorsport
1982 Mercedes 230 (W123) - White, bagged.
Hi Guys,finally got around to getting the car Diagnosed.Came up with errors intake manifold flap stuck,and missfire in cylinder 1.So any has a manifold to sell to me
