Catalytic converters Golf 6 GTI
- WesleyE
- Registered for: 11 years
- Car Model: VIVO
Hi Guys,
Hoping you can help.
This morning I drove my car, after 30 min of traffic driving suddenly the car started jerking.
Not long there after engine light came on and car isles like a truck . Difficult to rev up and really slow to drive.
Get to work and check the manual says light is for the catalytic converter.
These are extremely expensive to replace, my questions:
-can I replace with a down pipe
-if so what is the price I’ll be looking and are there recommendations? ( I’m based in Johannesburg South -Mondeor)
- I don’t have access to a diagnostic machine and don’t know anyone with one. Is there anyway of knowing for sure it is the cat converter?
Car is 2014 Golf 6 GTI manual, with 198++ kilo serviced last month and include plugs, filters and oil.
Thank you
Thank you
“I couldn’t repair your brakes, so I made your horn louder.”
- Colonel
- Car Model: Polo 1.0 R-Line
- Membership No: 1840
Re: Catalytic converters Golf 6 GTI
Sounds like a faulty pcv valve to me
2019 VW Polo Vivo GT 1.0TSI (Reef Blue Metallic)
2019 Toyota Rav-4 GX-R AWD (Graphite Grey Metallic)
2019 VW Polo 1.0 R-Line (Reef Blue Metallic)
2012 VW MKVI GTI (Candy White)
2011 VW Polo 6R Comfortline (Black Magic Pearl)
2008 Opel Corsa Lite+ (Silver)
1990 VW Fox 1.3 (Red)
- WesleyE
- Car Model: VIVO
Thank you Mitch, how can I check this or diagnoseMitch wrote:Sounds like a faulty pcv valve to me
- Belix
- Car Model: Passat B8
Yes, the light indicates a number of possible issues. You need to get car scanned at a VW agent, or someone with VCDS.
- mueneni12
- Car Model: MK6 GTI
Had this light on for a while. First vw says it is the cat sensor, replaced and did not solve the problem. Then they suspected it is the intake manifold - again did not resolve the issue. They ended up canceling the error, but doubt root cause was resolved.
Tommy
Daily: 2010 MK6 GTI Tornado Red
Occasional: 2014 Audi A8 V8 aka The Boat
Ego-stroker: 2007 Touareg V10
Hers: 2015 Honda Accord 3.5 Exclusive
Truck: 2013 Hilux V6 4.0 Heritage Edition
Sold: 2007 MK5 GTI Tornado Red
Stolen: 2015 Toyota Landcruiser V8 SC aka The Beast
- WesleyE
- Car Model: VIVO
Thanks for the replies, did a quick YouTube check to see if I could diagnose the PCV. Idled the car and pulled the dipstick no suction, then took the oil cap off still no suction idle does change slightly but does not die out.
Looking at the tailpipes it seems much darker than usually and extreme black residue in a powder form.
- dazza
- Car Make: VW and VW
- Membership No: 1327
Ever done/checked your chain tensioner? If the chain skipped a tooth or two your timing could be out and at the very worst you have an even bigger issue as a result
Darryn Van Rooyen
Current: 1987 Citi Sport 1.6
Current: 91 Citi Sport 1.3
12' MKVI GTI Manual
2009 Audi TT 2.0TFSI S-Tronic
08 RS MKV GTI DSG
09 ZG Ibiza Cupra TDI
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
12' MKVI GTI Manual
08 RS MKV GTI DSG
06 CW Sportline
01 Citi 1.4i
01 Yamaha YZ125
99 Toyota Tazz
94 Fox 1.8 Sport
- WesleyE
- Car Model: VIVO
Thanks for the replies guys, this morning dropped my son off at school. Car drive fine still had the check light on, as soon as I drop him off car starts jerking again low rpms loss of power and rough idle.
Get home and leave the car idling, start pulling each coil pack one by one. As soon as I pull each one car drops idle and is about to stall, did this except use for each coil pack.
None seem to be the problem, however rough idle fades away and car seems fine.
Check light still on, take a quick drive around the block and no issues.
Check on the car every hour , just started it now and engine light is off.
I’m not sure what the heck is going on, hopefully will have the car scanned tonight
- WesleyE
- Car Model: VIVO
Quick update, car scanned and no errors besides the light beam was picked up.
- Belix
No errors, but engine light on? Peculiar. Even if it goes on and off, it should log a fault until the codes are cleared. Who did the scan for you?
Did They check all the modules, gearbox included or just looked at engine? If the engine light went on and even it it self cancelled there must be a recorded fault somewhere.
- WesleyE
- Car Model: VIVO
I will request for log and update it here.
Honestly I don’t know how to read any of it and truth be told sigh of relieve when I was told no errors.
Not sure if related to the issue but worth mentioning.
About 3 weeks ago I saw what seemed to be a water leak, car was due for a service so asked them to check the water pump as that made sense. In checking the water pump was told that it’s not leaking and the water is actually coming from the connector hose running into the car (heater box?).
Didn’t get around to replacing it and I’ve been typing up water almost every second day. On the day the catalytic converter came on it basically only water no anti freeze. I’ve since topped up with anti freeze.
Car seems to be running fine for now, get paid next week so hoping to book the car in for a full bumper to bumper inspection, just need a reliable mechanic in the South of JHB.
I must mention that this car has a full service history and a call to VW confirmed that the Necessary recalls have been done.
- WesleyE
- Car Model: VIVO
Finally got my own OBD scanner, scanned car only fault was P0354, ignition coils. Suspected this as the only fix was removing and then re inserting coils. Will have a look at the spark plugs as soon as the engine cools down.
Find it strange that this is happening since I have the red top coil packs, reviews were great and no issues reported
could also be the plugs to the coils
- WesleyE
- Car Model: VIVO
Thanks Panic, will have a look at it
- Car Model: Mk5 gti
i had the same issue on my s3 the clips on the plugs might be broken or plugs might be old and under wot due to engine vibration they lose contact ...random misfire on 2 and 4 cylinder...i swopped the coils and it still misfired i swopped the plugs and it still misfired on cylinders 2 and 4 bought new plugs for R60 each cut and crimped the new ones on and kaboom problem solved no misfire .i have spare coils ,plugs and clips if u want to use them to CHECK free of charge... before u go out and spend a ton of cash .but i live in boksburg ...not sure whats ur location ...let us know if u come right and if u need help
viewtopic.php?f=11&t=217296
Previous :too many to list
- Wheel Whore
- Registered for: 6 years
- Car Model: MK5 GTI
Remove the dipstick while the car is idling and if it fixes the rough idle or you feel a strong vacuum coming from it, it's probably pcv. If the cat is clogged, there will be a light blue sort of residue at the Downpipe. Can just have the cat cut out for a fraction of the cost a new Downpipe if you don't want to spend money on a new 76mm one.
2008 Black Magic Golf 5 GTI - 194kw 414nm @ R&S Motorsport
1982 Mercedes 230 (W123) - White, bagged.
