dicktator 60-2 cranks sensor help
howzit gents
please may i ask for help i bought GW part no. 10703 sensor does anybody have the wiring lay out please so i can be sure
ps thanks duck and panic for your help
Re: dicktator 60-2 cranks sensor help
Pin 1 to red pin 1 on ecu plug, pin 2 to white on pin 11 on ecu plug, pin 3 on plug is the screen and connect thin black on ecu plug.
thanks papa will go check had so many problems with this change a few different sensor even fitted a wag toyota sensor viper help me with some dont even start the car at ALL
do you see rpm?. if not you might have to grind the little collar that is on the trigger away so it goes in the correct dept. Check it against what came out.
hey panic \ papa jo
i did still nothing checked wiring as above did check the dept the only a WAG auris sensor work still it gave in
Was the WAG auris sensor working for a short while? Tell us the part number.
it worked for long , i got it from wikus at delarey
Check if there is not a bad connection somewhere. Check up right into the lug on the ecu plug
the other sensor i used was a BMW e36 timing sensor had to modify but it worked
Rather use the known / proven working sensors, than modified ones. Less frustration and headaches.
