Mk5 gti oil
- Car Model: Mk5 gti
Mk5 gti oil
Hi guys ...and yes I know it's been discussed but when I try to search it says the search is ignored coz it's too commonly searched
So I wanted to find out which is the correct engine oil for a
2008 mk5 gti bwa 230 000km on the clock ...ive put in hx7 but the guys say it's the wrong oil and will cause premature cam shaft and lifter wear ...so what oil should I use? coz this is what goldwagon gave me
viewtopic.php?f=11&t=217296
Previous :too many to list
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Re: Mk5 gti oil
If it says VW 502 approved it should be fine.
Re: Mk5 gti oil
HX7 will not be a problem. Your car is not a Diesel with Pumpe Duze injectors. You are reading the wrong thread.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: Mk5 gti oil
Hx7 and ultra are fine. But they have a high evaporation loss so the boost pipes and intake end up with alot of oil in it. Rather look at a 504 oil or something with lower NOACK value. Should help with carbon buildup on valves.
Re: Mk5 gti oil
Ok thanks guys the hx7 says" vw 501.01/505.00"
So that meets the requirements
- ICE King
Re: Mk5 gti oil
Yes HX7 meets your GTI spec.
To clear up any confusion:
HX7 for both petrol & diesel engines(VW502.00 & 505.00):
https://www.shell.co.za/motorists/oils- ... 5w-30.html
AND
HX7 Pro AV ,specifically for Diesel engines (VW 502.00/505.01)
AND
Re: Mk5 gti oil
I have the 10w40
- ICE King
Re: Mk5 gti oil
10w40 is fine, wont do any harm.
1.The spec i.e 502.00/505.00 means that the oil/product provides adequate lubrication/protection required by the VW engine.
2.Mineral & Synthetic Oil (Full Synthetic actually doesn't exist) - difference is the refinement process & additives to the oil and it's benefits thereof.
3.Viscosity (measure of resistance of a fluid to a change in shape,movement) i.e 10W = measurement when cold , 40 = measurement at operating temperature.
Factory viscosity for your GTI (AFAIK) is 5w30 , but because you have a old car (more tolerances) , using 10w40 gives you the adequate protection but means the engine will have to work harder because oil is thicker = more heat , less performance, less fuel economy etc.....
Re: Mk5 gti oil
Thanks ice king for the thorough explanation ...im in the forum Coz I want to learn and today u thought me something by explaining the purpose of the numbers on the bottle and much more that I did not know ...atleast I understand after reading this how oil works thanks again bro
Re: Mk5 gti oil
The 40 is Ok for older engines and specially where they are known to have pressure issues which the BWA is. So no harm will come to your motor from that oil.
- ICE King
Re: Mk5 gti oil
Pleasure man, Glad I could pass on the info and it's of value to another. #winning.Trishen94 wrote: ↑Tue Apr 16, 2019 4:00 pm Thanks ice king for the thorough explanation ...im in the forum Coz I want to learn and today u thought me something by explaining the purpose of the numbers on the bottle and much more that I did not know ...atleast I understand after reading this how oil works thanks again bro
This is the beauty of any forum, getting to interact/learn/help people with similar interest.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
Re: Mk5 gti oil
Just to add on point 2.ICE King wrote: ↑Tue Apr 16, 2019 3:01 pm 10w40 is fine, wont do any harm.
While it is hard to find a truely full synthetic oil they do exist. Some of Motul 8100 range and some of the castrol oils come to mind. These have a proper Group 4 base oil.
Alot of the other oils like the Shell helix and Liquimoly oils use a treated mineral oil(group 3) as the base oil and add some synthetic on top of that. But having said that, its not terrible to have a treated group3 base oil.
Viscosity is a bit more tricky. VW502/504 etc have requirements for viscosity and because of the range given you can either endup with a thick 30 weight oil or a thin 40 weight oil. The Helix range is actually pretty thin as a 40 at 13.1CST at 100C so not a lot thicker than most of the 30 weight oils. You won't have any issues there.
The viscosity that also matters is the HTHS which is >3.5 on VW approved oils.
Re: Mk5 gti oil
There is a for sale forum for that. This is the tech forum.
Re: Mk5 gti oil
This ou is spamming all the threads with his for sale post. He's made a number of posts in a few threads.panic-mechanic wrote:There is a for sale forum for that. This is the tech forum.
I smell a ban coming.
- Sebz
- Car Make: BMW
- Car Model: 135i E82 N54 ST 6MT
- Membership No: 3020
Re: Mk5 gti oil
Your nose is really good... Please can you smell the upcoming Lotto numbers for me too?
Single turbo BMW 135i N54 6MT
Ex's:
Brilliant BMW 135i E82 N55 6MT
Stupidly static THANAS Tuned '05 Audi A4 B7 2.0T FSi
Definitely down-to-earth '03 Audi A3 8L 1.8T
Ludicrously lowered K04 '03 Audi A4 Avant B6 1.8T
Sorta slammed '15 VW Polo Vivo GT 1.6
Stock standard '05 Opel Corsa D Ute 1.4
Ridiculously reliable '81 VW Passat CSL Estate 2.2 5-pot
It's not how you stand by your car; it's how you scrape your car. You better learn that.
Ex's:
- Car Model: White-G5 GTi
Re: Mk5 gti oil
CASTROL EDGE 5w40,...hy werk baie mooi vir my!
