Mk5 GTI Power Loss
Mk5 GTI Power Loss
HELP NEEDED.
Any ideas on me mk5 golf gti .
Changed
Coil
Accel pedal
Throttle body
Fault codes
P0222 - Throttle angle sensor
P0123 - throttle position sensor to high
P02122 - accel position sensor to low
P0642 - sensor ref voltage A to low
P0698 - sensor ref voltage to low
It’s ok if I don’t boost it. Once I kick over 3000 revs especially in 3rd / 4thgear it either goes into limp mode, EPC-Enginemanagment and traction control lights come on and I lose power but still drive it OR completely packs in EPC and traction light but no revs undrivable. All I do is disconnect battery then it’s fine
Please can any1 Advise. I unplugged the MAP Sensor and it was ok for a while, Ran better but its started cutting out again.. Im at my wits end
Changed
Coil
Accel pedal
Throttle body
Fault codes
- Titleists
- Philosopher STIG
- Car Model: 2016 Golf R
- Membership No: 1520
Re: Mk5 GTI Power Loss
Have you tested the battery itself?
- Titleists
- Philosopher STIG
Dead batteries can cause all sorts of random errors.
- Car Model: Mk5 gti
Also curious to know this sounds like a strange 1 to me also
viewtopic.php?f=11&t=217296
Previous :too many to list
then dead throttle body or the control circuit in the management is fried.
Ive replaced throttle body,panic-mechanic wrote: ↑Fri Apr 12, 2019 11:49 am then dead throttle body or the control circuit in the management is fried.
"control circuit in the management is fried" Whats this mean
Have you tried changing the pedal?
The control circuit fried means you need a new ecu. Just make sure the plug that goes into the throttle body is in good condition.
Yeah ive replaced the Pedalpanic-mechanic wrote: ↑Mon Apr 15, 2019 6:13 am Have you tried changing the pedal?
Then you have either a wiring issue or ECU.
