Golf 5 GTI Misfire
Golf 5 GTI Misfire
HI there
I have a Golf 5 GTI Unique Motorsport stage2 software and downpipe...
between 3000 and 4000 RPM the car misfires...
According to Unique Motorsport, I have to replace the coils...
There was nothing wrong with coils, or any misfire before software upgrade...
Pls can any one HELP??
Jean
074 621 6483
Jean
074 621 6483
Re: Golf 5 GTI Misfire
Sounds more like the tuner blames coils now for his map that might not be right.
How is the condition of the sparkplugs and are they set to the correct gap?
Can you get some logs to determine what causes this?
hi there
this was the second map...
first one no misfire...
I will replace plugs, and go back to get logs...
I think he only wants to sell me R8 coils...
and every time something else...
thanx will c after this...
- dcmk4
- Car Model: MK7 GTi
If he has a set of coils and conveniently blames them to tell you that you need new coils, it's far too ironic to claim it's coils randomly.
Does it clear up after 4k?
hi there
Yes it does clear after 4k... and tuner dyno claims 185kw and 404nm but it really does not feel like it...
- Car Model: Mk5 gti
Where are u based ? If u close to boksburg i have a spare set of coils and plugs that u can put into your car and test 1st ...dont buy anything yet coz they will not refund you ...u know the rule with electronic items ...(to my understand but stand to be corrected) ...if it is a coil or plug it will mis fire from 0 to red line not inbetween or at certain revs
viewtopic.php?f=11&t=217296
Previous :too many to list
hi there
thank you, I did buy plugs will change them tomorrow...
I was at Etuners today and they also advised plugs and coils...
thank you for the offer will let you know...
Jean (i'm in PTA)
Jean (i'm in PTA)
Another tuner that does not even own a dyno.... Sigh. What is the world coming to. Please rather call him a file loader. Better description.
Lmaopanic-mechanic wrote: ↑Thu Apr 04, 2019 8:39 am Another tuner that does not even own a dyno.... Sigh. What is the world coming to. Please rather call him a file loader. Better description.
- A3-BTFSI
- Wheel Whore
- Car Model: A3 8v 1.8TFSI Stage 2
Yeah start with plugs and coils but get the car to someone who can scan it to see if it brings up an errors.
- Killerwatt
- Car Make: AUDI
- Car Model: S3
What plugs did you get? What is the gap on them?
If it is a coil then log the car to see which cylinder the missfire occurs on. Then swap the coil from that cylinder to another one. If the missfire moves with the coil then you know that the coil is at fault.
- Committee Member
- Car Model: Audi S3 Sedan
- Membership No: 1215
Coils are a very common failure on TFSI/tsi's after loading software, especially st2 and up. I've had this countless times on the older TFSI/TSI's
Get vagcom, see which cyl is misfiring, swop coils to see if the misfire follows the coil, if it does, replace it. If not, Do the same with plugs
99% sure this will solve your problem
Grant Hendry
Membership no.:1215
2016 Audi S3 Sedan
1978 VW Golf 1100 GL
2012 VW Golf GTI Edition 35
2007 VW Golf GTI
2006 Polo 1.9 TDI Sportline
2012 VW Polo GTI
Membership no.:1215
2016 Audi S3 Sedan
2007 VW Golf GTI
2012 VW Polo GTI
long time ago there was actually a replacement campaign for coil replacements so it is a common issue yes. And no the campaign ended long time ago , you can't get free coils from your dealer anymore.
hi there
Unique Motorsport told me to get the red R8 coils...
I will install them with new NGK PFR7S8EG plugs...
Thanx for all the advice...
the red ones are much prettier yes.
- Car Model: White-G5 GTi
Few years back when I loaded SW on my car @ Experience Performance in Durban it did the same.
Car at the time was stock and SW was my first mod.
On the dyno before the SW was loaded car was fine, after SW loaded car did what you are describing. Fitted coils from a Polo GTi that was there at the time and all was fine,..went to buy Red-Top-Coils and never had issue, (car since few other upgrades Intake, DP etc...)
Logging the car would be your first step tho,..
I will do just that thank you..
hi there
can anyone help me pls my golf 5 GTI right read door wont lock...…
thanx
thanx
Yes, buy new lock from vw, replace current lock. Fixed.
HI there
Yes i removed the lock actuator, will get new one tody...
Thanx
Thanx
