Turbo Manifold
Turbo Manifold
Hi guys I would appreciate your help, My Golf 5 GTI is leaking on the turbo, the mechanic found out that on the turbo Manifold (K03) they is this some kind of the plate that enter and lock the manifold from moving this plate usually be on the lower part they are two they go in before the nuts on the manifold, one is missing causing the manifold leak, I want to know the name of that plate and where I can find it.
Re: Turbo Manifold
Its called a wastegate flap. It is no longer closing/sealing properly due to age probably and the manifold housing is probably cracked at bottom as well.
Replace turbo unfortunately. Good news is that you can reuse the gaskets with some rtv grey paste
Re: Turbo Manifold
I think what he is looking for is the taper plate that holds the manifold on.
Part no 06F 253 709 A
